17268 Discussions
Type problem? Compiler doesn't help me!
Hi everyone,
My software works for the compilation.
But now I had a table 7seg to display my work. But it doesn't compile without error!
I'm lost.
My two questions are:
questions 1):
Why this line is not working?
type rang0to15 is natural range (0 to 15); --With or without () have the same error message!
--Error (10500): VHDL syntax error at LabProfBCD4Bits.vhd(25) near text "natural"; expecting "(", or "access", or "array", or "file", or "range", or "record"
questions 2):
Q7Seg <= Table_Nbres((0 to 15)iCntBCD); --Outgoing: 7SegLED with cast of type
--Error (10500): VHDL syntax error at LabProfBCD4Bits.vhd(51) near text ")"; expecting "!", or "=>"
Thank you in advance for your help.
Part of my soft :
--4 bits BCD counter.
-- VHDL Language and Board: : ? (not with me right now!)
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity LabProfBCD4BITS is
port(
Clk: in std_logic;
nReset: in std_logic;
Q: out std_logic_vector(3 downto 0);--For testing soft in simulation.
Q7Seg: out std_logic_vector(7 downto 0) –New version.
end entity LabProfBCD4BITS;
architecture bhv of LabProfBCD4BITS is --CntBCD is
signal iCntBCD: natural (3 downto 0);--Signal for internal computing.
constant MaxDelay: natural :=50000-1;
signal iCntDelay: natural range 0 to MaxDelay;
signal CntUpBCD: std_logic;--to increment iCntBCD.
--type rang0to15 is natural range (0 to 15); --With or without () have the same error message!
--type tBCD7Seg is array (rang0to15) of std_logic_vector(7 downto 0); --it doesn’t work!?!
type tBCD7Seg is array (0 to 15) of std_logic_vector(7 downto 0); --With bit_vector, it looks also working.
constant Table_Nbres : tBCD7Seg := (
-- Dpgfedcba
"00111111", -- 0
"00000110", -- 1
"01011011", -- 2
{[And so on]}
"11111001", -- D --show "E.", means Error.
"11111001", -- E
"11111001" -- F
begin
Q <= std_logic_vector(iCntBCD);--Used for simulation. Work well.
--Q7Seg <= Table_Nbres(iCntBCD); --Outgoing: 7SegLED without cast of type
--Error (10380): VHDL error at LabProfBCD4Bits.vhd(20): natural type is used but not declared as an array type
{[The line 20 is: signal iCntBCD: natural (3 downto 0);--
In this case, the error is that no have a cast. Both type are different.]}
1. This is a mix up between two things. You have a mix of subtype syntax and type syntax. A type will declare a brand new type, like an array type, or enumerated type. (0 to 15) would be used when declaring an array or an array type:
eg:
type my_array_t is array(0 to 10) of integer;
signal sig : std_logic_vector(7 downto 0);
What it look like you are trying to do, is declare a subtype, as you are limiting the range of an existing type:
subtype rang0to15 is natural range 0 to 15; -- no () needed
2. I dont quite know what this is - but it is not legal. And I dont know what the Table_Nbres type is. You also cannot declare a range as a type.
Did you mean:
Q7Seg <= Table_Nbres(0 to 15);
This is also broken, because rang0to15 is not legal. You could write:
type tBCD7Seg is array (rang0to15'low to rang0to15'high) of std_logic_vector(7 downto 0);, but it would be more sensible to write
Thank you for your answer,
--- Quote Start ---
--- Quote End ---
Yes you are right.
--- Quote Start ---
2. And I don't know what the Table_Nbres type is. You also cannot declare a range as a type.
--- Quote End ---
The type of Table_Nbres is:
The type of Q7Seg is : (Declared in entity)
The type of iCntBCD is: This var contains the position in the table Table_Nbres.
Now; Q7Seg <= Table_Nbres((0 to 15)iCntBCD);
(0 to 15) is a cast for iCntBCD
IS IT RIGHT to declar the cast like this? OR WHAT IS WRONG?
Thanks for your reply.
Is illegal. naturals and other integer types do not have accessible bits. Also, 3 downto 0 is illegal for an integer type.
did you mean
signal iCntBCD : natural range 0 to 3;
--- Quote Start ---
--- Quote End ---
You cannot do this. I still cannot quite see what you're trying to do.
--- Quote Start ---
did you mean
--- Quote End ---
No, not with range. With range means, only the value 0, 1, 2 and 3 is available. AM I RIGHT?
My thaught was:
I want an unsigned integer counter with 4 bits. (And, in plus, init at 0)
But if I write:
signal iCntBCD : unsigned integer :=0;--I have a counter of 32 bits. AM I RIGHT?
When I want to add 1 to iCntBCD, I have to write:
iCntBCD = iCntBCD + 1 ;
When I want to send iCntBCD to Q output, I have to cast iCntBCD, like this:
Q <= std_logic_vector (iCntBCD);--Like I did.
I hope it send to Q only the 4 LSB and ignorre the others bits without any error during compilation!
If I want only 4 bits, I must write:
signal iCntBCD : std_logic_vector(3 downto 0) := '0000'; -- AM I RIGHT?
iCntBCD <= (iCntBCD + '1') :--IS IT CORRECT?
When I want to send iCntBCD to Q output, I have to do, without cast, like this:
Q <= iCntBCD; --No cast, because both have the same type.
Which methode, do you think is better?
IF EVERY THING IS OK, I will modify my software and test it tomorrow, if the classroom is open. If not I will do it Monday afternoon, swiss time.
I think, I'm starting to understand what's going on!
thank you very much.
I will send you an other message with your second answer soon.
--- Quote Start ---
--- Quote End ---
No - there is no such thing as an unsigned integer type in VHDL. The integer type has no bits, and integer is always signed.
I think you mean the unsigned type:
signal iCntBCD : unsigned(3 downto 0) := to_unsigned(0, iCntBCD'length); --then add one: iCntBCD <= iCntBCD + 1;
--- Quote Start ---
--- Quote End ---
Yes, you can do that - but why make Q a std_logic_vector? why not declare it unsigned and then no type conversion is needed.
--- Quote Start ---
--- Quote End ---
You mean "0000" - ' denotes a single character, " is for strings.
This code will only work with non-standard vhdl - it requires the std_logic_unsigned package - this is not a VHDL standard.
Personally, I use the first method as that is what is required in most industry - using Standard VHDL. But I would leave the Q output as unsigned. the second method is non standard.
