- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
This is the simplest design I could think of, something to light up the LEDs. Compilation runs fine with no errors and few warnings.
When I try to program the device in the Programmer window this is the sequence of actions I perform. 1. Since nothing shows up initially I select "Auto Detect" 2. Select device which 5CSEMA5 3. I select 5CSEMA5, right click and add the .sof file 4. At that point I have 3 items in the TDI/TDO chain SOCVHPS, 5CSEMA5 and 5CSEMA5F31. 5. Running "Start" instantly changes the progress to failed I have tried to remove the either or both of the SOCVHPS/5CSEMA5 items from the chain and then programming it. This has not helped at all. I can not view what error causes the progress bar to fail.- Etiquetas:
- Intel® Quartus® Prime Software
- programmer
Enlace copiado
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Windows 11 Home
11th Gen Intel(R) Core(TM) i3-1115G4 @ 3.00GHz 3.00 GHz
64-bit operating system, x64-based processor
Same problems. Here is how my problem solution list...
1. Problem1: DE1-SOC not recognizing "Hardware Setup" as per no characters visible in the adjacent block to the right.
1a. Solution1: I installed the wrong version. I downloaded and installed the "light" 23.1.1 free version. Afterwards the USB cable was recognized as "DE-SoC [USB-1]"
2. Problem2: Programmer would "fail" after pressing the "Start" button. See my PDF guide
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Same in pics...
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Linux Mint 21.3 Cinnamon / Cinnamon Version 6.0.4 / Linux Kernel 5.15.0-122-generic / Processor Intel© Core™ i3-4030U CPU @ 1.90GHz × 2 / Memory 3.7 GiB / Graphics Card Intel Corporation Haswell-ULT Integrated Graphics Controller241.1 GB / Display Driver X11
Was having the exact same troubles using this linux OS with programmer not working. I lost track of the multiple lateral, forward, and backward steps to get this to work, but I ultimately did using the same steps as above,,, except 1 additional at the onset,,,, see below...
1. Problem1- programmer not working.
1.5. Solution1- reinstalled the free light version. I had the other and it was not recognizing the USB A to B data cable.
2. Solution1- I reconfigured the switches on the bottom of the fpga board: Per User Manual, 3.1 Settings of FPGA Configuration Mode- "If developers wish to reconfigure FPGA from an application software running on Linux, the MSEL[4:0] needs to be set to 01010 before the programming process begins".
3. Solution1- Followed the same previous posted guide. Worked fine,,, fiNAlleee :). Now to create stuff...
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
We sincerely apologize for the inconvenience caused by the delay in addressing your Forum queries. Due to an unexpected back-end issue in our system, your Forum cases, along with others, did not get through as intended. As a result, we have a backlog of cases that we are currently working through one by one.
Please be assured that we are doing everything we can to resolve this issue as quickly as possible. However, this process will take some time, and we kindly ask for your patience and understanding during this period. The cases will be attended by AE shortly.
We appreciate your patience and understanding, and we are committed to providing you with the best support possible.
- Marcar tema como nuevo
- Marcar tema como leído
- Favorito
- Suscribir
