17253 Discussions
Unable to run Intel HLS examples
NSuku1
Hi all,
I installed the Quartus Prime Pro version 17.1 with HLS compiler and Microsoft Visual Studio 2015 Professional. I followed the steps given in the HLS compiler getting started guide. When I ran the following command
init_hls.bat
It was complaining for the Visual Studio path and I have setup manually.
When I ran the examples such as QRD or Counter, I get the following errors as
string.h not found or queue not found
which means that it is unable to locate the standard libraries.
I would like to know whether the Visual Studio should be in specific path for the HLS to use ?
How does the HLS finds these standard libraries?
Kindly help me in resolving these issues.
Thanks in advance!
Nivetha
Abe
Valued Contributor II
Which version of Visual Studio have you installed.. have you installed the one supported by Intel Quartus tools aka 2010 version?
NSuku1
Hi!
I mentioned that I have installed Quartus Prime Pro 17.1 with Microsoft Visual Studio 2015 which is mentioned by Intel.
Abe
Can you try running the init_hls.bat file in an elevated command prompt (one with Administrator privileges) and check if it works.
NSuku1
Hi! Thanks for helping me in resolving this issue. I will try whether it works with the admin rights. But, I am afraid that I may not be able to get the admin rights always to use the tools.
Nivetha
