Annonces
17267 Discussions
Unexpected transport delays in functional simulation
AlenaK
Débutant
1 712 Visites
we're trying to verify a circuit using Functional Simulation. We know that output signal goes to state '0' at the clock's rising edge. But we see the output switching delay.
So, the question is why Quartus takes into account transport delay in this simulation mode? Perhaps, we can turn off transport delays for functional simulation? Could anyone help us? Thank you!
0 Compliments
3 Réponses
KennyTan_Altera
Modérateur
1 364 Visites
Hi Alena,
What device that you were using? timing simulation should be avoided as it take long time. We would suggest to use timing analyzer instead.
0 Compliments
sstrell
Contributeur émérite III
1 364 Visites
It's unlikely that you're seeing a transport delay when performing a functional simulation. Are you saying the output is going low between the current and next clock edges?
As mentioned, try using the timing analyzer on the output path to see if the design is failing timing.
#iwork4intel
0 Compliments
KennyTan_Altera
Modérateur
1 364 Visites
Is there any update?
0 Compliments
Répondre
