公告
17268 讨论
Unsigned to signed conversion and its simulation in Modelsim
名誉分销商 II
8,950 次查看
Hello dear friends,
I am having an unsigned number of the input and need to sign extend it and negate (2s representation) if in the specific condition occurs (say if sign=1, to simplify)
Here is my code in SystemVerilog:
module signed_unsigned (
sign,
clk,
data_in,
data_out);
input logic sign;
input logic clk;
input unsigned [7:0] data_in;
output signed [8:0] data_out;
always_ff @ (posedge clk) begin
if (sign)
data_out <= -data_in;
else
data_out <= data_in;
end
endmodule
It looks like it analyzed properly in Quartus (see RTL representation in the attachment). However, when I simulate in Modelsim it doesn't show the correct result.
In the testbench I have a clock generator and just assignments to the data_in. I expect to see 101 value for 0xFF, 156 for 0xAA, etc but nothing happens. the numbers are same
What can be wrong? I am very confused.
Cheers,
0 项奖励
3 回复数
名誉分销商 II
6,556 次查看
I will use signed(for unsigned addt one MSB at zero)
e.g. assuming 8 bit signed:
if...
data <= input;
else
data <= -input
end
0 项奖励
名誉分销商 II
6,556 次查看
This works for me after making one correction unrelated to the signed issue. data_out needs to be a variable in order to make procedural assignments to it. You have it declared as a wire. (you are also using Verilog-1995 style ports, which I updated)
module signed_unsigned ( input logic sign, input logic clk, input unsigned data_in, output logic signed data_out ); always_ff @ (posedge clk) begin if (sign) data_out <= -data_in; else data_out <= data_in; end endmodule
It would have helped to show the testbench you were using. Here is what I used.
module top; bit clk, sign; logic unsigned data_in; logic signed data_out; always# 5 clk++; initial begin sign=1; data_in = 8'hff; @(negedge clk) $displayh(data_in,,data_out); data_in = 8'hAA; @(negedge clk) $displayh(data_in,,data_out); sign=0; data_in = 8'hff; @(negedge clk) $displayh(data_in,,data_out); data_in = 8'hAA; @(negedge clk) $displayh(data_in,,data_out); $finish; end signed_unsigned su(.*); endmodule : top
And the output I got
# Loading work.top(fast) # run -all # ff 101 # aa 156 # ff 0ff # aa 0aa # ** Note: $finish : signed.sv(25)
0 项奖励
名誉分销商 II
6,556 次查看
Thank you, dave_59. It is working now! My testbench was a bit crooked too :)
0 项奖励
回复
