17268 Discussions
Urgent !! Re-editing a component in SOPC 9.1
Hello
I already create a new component in SOPC (Quartus 9.1) .
I need to edit new modifications to that component but the problem is that i can't edit it !! It can't even click on the button edit !
Thank's for any help
you mean, you can't select the edit property on your component inside the sopc builder when you right clic on it ?
close the sopc builder
open the *_hw.tcl file of your ip
search for this line
--- Quote Start ---
set_module_property EDITABLE false
--- Quote End ---
and change it to
--- Quote Start ---
set_module_property EDITABLE true
--- Quote End ---
now if you reopen your sopc builder project then you should be able to edit the component
this bug/feature of not be able to edit an existing component has been introduced somewhere around quartus 9.0 where all custom ip's where suddenly not editable
Thank you so much
You helped me a lot
