- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
Hello, I am currently working on ALTERA DE2-115 kit cyclone 4 e. I want to display the count (0-9) with specific delay between every count. please provide code.
- Balises:
- Intel® Quartus® Prime Software
Lien copié
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
you'd get the code quicker if you wrote it yourself.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
sir I am the beginner and I dont have much of knowledge of the verilog programming. I tried to write the code but the results are not as desired. please help.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
We were all beginners once. Why not find a verilog tutorial and start learning, like everyone else did?
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
You won't learn anything by asking others to do your homework for you.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
This is the code which I have written to check whether lcd displayes anything. tell me if I have made a mistake anywhere.
Diplaying Characters To The LCD via FPGA ------------« Begin Code »------------ .. ... -------------------Write 'P'------------------- when S9 => current_state <= S10; LCD_DATA <= x"50"; LCD_ENABLE <= '1'; LCD_RW <= '0'; LCD_RS <= '1'; when S10 => current_state <= S11; LCD_DATA <= x"50"; LCD_ENABLE <= '0'; LCD_RW <= '0'; LCD_RS <= '1'; -------------------WRITE 'Y'------------------- when S11 => current_state <= S12; LCD_DATA <= X"59"; LCD_ENABLE <= '1'; LCD_RW <= '0'; LCD_RS <= '1'; when S12 => current_state <= S13; LCD_DATA <= X"59"; LCD_ENABLE <= '0'; LCD_RW <= '0'; LCD_RS <= '1'; -------------------WRITE 'R'------------------- when S13 => current_state <= S14; LCD_DATA <= X"52"; LCD_ENABLE <= '1'; LCD_RW <= '0'; LCD_RS <= '1'; when S14 => current_state <= S15; LCD_DATA <= X"52"; LCD_ENABLE <= '0'; LCD_RW <= '0'; LCD_RS <= '1'; ... .. ------------« End Code »------------- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
This is the code written to display some numbers on lcd.
ASCII to Numbers/Letters ------------« Begin Code »------------ .. ... -------------------Function Set------------------- when S0 => current_state <= S1; LCD_DATA <= "00110000"; LCD_ENABLE <= '0'; LCD_RW <= '0'; LCD_RS <= '0'; when S1 => current_state <= S2; LCD_DATA <= "00110000"; LCD_ENABLE <= '1'; LCD_RW <= '0'; LCD_RS <= '0'; when S2 => current_state <= S3; LCD_DATA <= "00110000"; LCD_ENABLE <= '0'; LCD_RW <= '0'; LCD_RS <= '0'; -------------------Reset Display------------------- when S3 => current_state <= S4; LCD_DATA <= "00000001"; LCD_ENABLE <= '0'; LCD_RW <= '0'; LCD_RS <= '0'; when S4 => current_state <= S5; LCD_DATA <= "00000001"; LCD_ENABLE <= '1'; LCD_RW <= '0'; LCD_RS <= '0'; when S5 => current_state <= S6; LCD_DATA <= "00000001"; LCD_ENABLE <= '0'; LCD_RW <= '0'; LCD_RS <= '0'; -------------------Display On------------------- when S6 => current_state <= S7; LCD_DATA <= "00001110"; LCD_ENABLE <= '0'; LCD_RW <= '0'; LCD_RS <= '0'; when S7 => current_state <= S8; LCD_DATA <= "00001110"; LCD_ENABLE <= '1'; LCD_RW <= '0'; LCD_RS <= '0'; when S8 => current_state <= S9; LCD_DATA <= "00001110"; LCD_ENABLE <= '0'; LCD_RW <= '0'; LCD_RS <= '1'; ... .. ------------« End Code »------------- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Are you sure you wrote it? it's VHDL, not verilog.
Why not try compiling the code and putting it on the board, or even better write a testbench and try the code in a simulator?- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I tried it just to check whether the logic of the program is correct. I also put it on the board, but the output is not as desired. The lcd screen was not getting clear either.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
The actual task is transmission of stream of data via Ethernet. But I am not able to crack that either. I am stuck in this lcd code.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I highly suggest you write a testbench so you can debug your code to ensure the output is what you desire (you'll need that for ethernet anyway)
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
