17254 Discussions
Urgent help in verilog code for cyclone 4 e
Hello, I am currently working on ALTERA DE2-115 kit cyclone 4 e. I want to display the count (0-9) with specific delay between every count. please provide code.
you'd get the code quicker if you wrote it yourself.
sir I am the beginner and I dont have much of knowledge of the verilog programming. I tried to write the code but the results are not as desired. please help.
We were all beginners once. Why not find a verilog tutorial and start learning, like everyone else did?
You won't learn anything by asking others to do your homework for you.
This is the code which I have written to check whether lcd displayes anything. tell me if I have made a mistake anywhere.
Diplaying Characters To The LCD via FPGA
------------« Begin Code »------------
-------------------Write 'P'-------------------
when S9 =>
current_state <= S10;
LCD_DATA <= x"50";
LCD_ENABLE <= '1';
LCD_RW <= '0';
LCD_RS <= '1';
when S10 =>
current_state <= S11;
LCD_DATA <= x"50";
LCD_ENABLE <= '0';
LCD_RW <= '0';
LCD_RS <= '1';
-------------------WRITE 'Y'-------------------
when S11 =>
current_state <= S12;
LCD_DATA <= X"59";
LCD_ENABLE <= '1';
LCD_RW <= '0';
LCD_RS <= '1';
when S12 =>
current_state <= S13;
LCD_DATA <= X"59";
LCD_ENABLE <= '0';
LCD_RW <= '0';
LCD_RS <= '1';
-------------------WRITE 'R'-------------------
when S13 =>
current_state <= S14;
LCD_DATA <= X"52";
LCD_ENABLE <= '1';
LCD_RW <= '0';
LCD_RS <= '1';
when S14 =>
current_state <= S15;
LCD_DATA <= X"52";
LCD_ENABLE <= '0';
LCD_RW <= '0';
LCD_RS <= '1';
------------« End Code »------------
This is the code written to display some numbers on lcd.
ASCII to Numbers/Letters
-------------------Function Set-------------------
when S0 =>
current_state <= S1;
LCD_DATA <= "00110000";
LCD_ENABLE <= '0';
LCD_RW <= '0';
LCD_RS <= '0';
when S1 =>
current_state <= S2;
LCD_ENABLE <= '1';
LCD_RW <= '0';
LCD_RS <= '0';
when S2 =>
current_state <= S3;
LCD_ENABLE <= '0';
LCD_RW <= '0';
LCD_RS <= '0';
-------------------Reset Display-------------------
when S3 =>
current_state <= S4;
LCD_DATA <= "00000001";
LCD_ENABLE <= '0';
LCD_RW <= '0';
LCD_RS <= '0';
when S4 =>
current_state <= S5;
LCD_ENABLE <= '1';
LCD_RW <= '0';
LCD_RS <= '0';
when S5 =>
current_state <= S6;
LCD_ENABLE <= '0';
LCD_RW <= '0';
LCD_RS <= '0';
-------------------Display On-------------------
when S6 =>
current_state <= S7;
LCD_DATA <= "00001110";
LCD_ENABLE <= '0';
LCD_RW <= '0';
LCD_RS <= '0';
when S7 =>
current_state <= S8;
LCD_ENABLE <= '1';
LCD_RW <= '0';
LCD_RS <= '0';
when S8 =>
current_state <= S9;
LCD_ENABLE <= '0';
LCD_RW <= '0';
LCD_RS <= '1';
Are you sure you wrote it? it's VHDL, not verilog.
Why not try compiling the code and putting it on the board, or even better write a testbench and try the code in a simulator?
I tried it just to check whether the logic of the program is correct. I also put it on the board, but the output is not as desired. The lcd screen was not getting clear either.
The actual task is transmission of stream of data via Ethernet. But I am not able to crack that either. I am stuck in this lcd code.
I highly suggest you write a testbench so you can debug your code to ensure the output is what you desire (you'll need that for ethernet anyway)
