I just upgraded my computer (Ubuntu 16.04) from 64Gb to 256Gb of RAM. I use Quartus Prime Pro 22.4, and I didn't gain not even 1 sec on compilation time, it still takes 13min05 exactly.
I thought this would make it faster so it's a bit frustrating.
I ensured that I use the 16 cores for parallel compilation (Intel® Xeon(R) W-2245 CPU @ 3.90GHz × 16).
I don't know where to check in the compilation flow report the amount of RAM memory used during compilation ?
I know that this can depend also on the design, constraints, etc... but I expected at least a small improvement !
Any suggestion ? Can I specifiy the amount of RAM memory used during compilation ?
Thanks !
You don't mention what device you are compiling for, but you were already at 64 GB which is good for up to Stratix 10. Newer devices (like Agilex) would probably benefit from more RAM. So I'd bet you're limited by compute/processor power, not RAM, at this point.
The compilation report that pops up at the end of compilation should show RAM usage.
Sorry completely omitted this, it's Arria 10. But as you mention and I could read this also, I believe 64GB is enough for such devices. I don't want to modify compilation settings with optimizations because I'm afraid of performances alterations, so I'll keep with that, 13min is not so bad !
I also believe you are gated by the number of processor. 13 min is also not a very long compilation time.
If you interest to reduce the compilation time, you may refer to the "Reducing Compilation Time" in volume 2 of the Quartus II Handbook.
Richard Tan
p/s: If you find any answers from the community or Intel Support to be helpful, we encourage you to mark them as the best answer or rate them 4/5 in the survey.
