17255 Discussions
Using Quartus Pro SW 18.0 tool crashes during placement stage. I am looking for a workaround to avoid this crash.
Balaji_G_Intel
Info (170191): Fitter placement operations beginning
Internal Error: Sub-system: VPR20KMAIN, File: /quartus/fitter/vpr20k/dap/dap_initial.cpp, Line: 7130
Internal Error
Stack Trace:
  0xb7992: vpr_qi_jump_to_exit + 0x6f (fitter_vpr20kmain)
  0x169fb9: vpr_exit_at_line + 0x83 (fitter_vpr20kmain)
  0x72eb50: l_dap_initial_placed_at_hint_location() + 0x2cb0 (fitter_vpr20kmain)
  0x5829bd: dap_initial_placement + 0x78d (fitter_vpr20kmain)
  0x72b211: dap_do_initial_placement_phase + 0x81 (fitter_vpr20kmain)
  0x723d15: dap_try_place + 0x95 (fitter_vpr20kmain)
  0x63ed0a: aa_flow_do_placement_attempt + 0x2a (fitter_vpr20kmain)
  0x6074b7: aa_flow_place + 0x167 (fitter_vpr20kmain)
  0x5a69ff: (anonymous namespace)::place_internal(e_fitter_flow_stage, unsigned long long*) [clone .constprop.4613] + 0xf (fitter_vpr20kmain)
  0xda1f4: VPR_QI_FACADE::post_bsyn_placement_flow() + 0x48 (fitter_vpr20kmain)
  0x73ce7: VPR_QI_FACADE::vpr_bsyn_flow(bool, bool) + 0x53 (fitter_vpr20kmain)
  0x6fef4: FDRGN_EXPERT::run_vpr(bool, bool, bool, bool, BSYN_FLOW_TYPE) + 0x194 (fitter_fdrgn)
  0x29869: fit2_fit_place_auto + 0x143 (comp_fit2)
  0x4c977: TclNRRunCallbacks + 0x47 (tcl8.6)
  0x13eb3: fit2_fit_place + 0x2d7 (comp_fit2)
  0x4e1ca: TclEvalEx + 0x96a (tcl8.6)
  0xf68c6: Tcl_FSEvalFileEx + 0x266 (tcl8.6)
  0xf69ce: Tcl_EvalFile + 0x2e (tcl8.6)
  0x1268c: qexe_evaluate_tcl_script(std::string const&) + 0x397 (comp_qexe)
  0x16a26: qexe_do_tcl(QEXE_FRAMEWORK*, std::string const&, std::string const&, std::list<std::string, std::allocator<std::string> > const&, bool, bool) + 0x6bf (comp_qexe)
  0x17b17: qexe_run_tcl_option(QEXE_FRAMEWORK*, char const*, std::list<std::string, std::allocator<std::string> >*, bool) + 0x5df (comp_qexe)
  0x39c50: qcu_run_tcl_option(QCU_FRAMEWORK*, char const*, std::list<std::string, std::allocator<std::string> >*, bool) + 0xd85 (comp_qcu)
  0x1b497: qexe_standard_main(QEXE_FRAMEWORK*, QEXE_OPTION_DEFINITION const**, int, char const**) + 0x483 (comp_qexe)
  0x3f490: msg_main_thread(void*) + 0x10 (ccl_msg)
   0x671c: thr_final_wrapper + 0xc (ccl_thr)
  0x3f54f: msg_thread_wrapper(void* (*)(void*), void*) + 0x62 (ccl_msg)
  0x10f69: mem_thread_wrapper(void* (*)(void*), void*) + 0x99 (ccl_mem)
   0x8d68: err_thread_wrapper(void* (*)(void*), void*) + 0x27 (ccl_err)
   0x675f: thr_thread_wrapper + 0x15 (ccl_thr)
  0x41e8b: msg_exe_main(int, char const**, int (*)(int, char const**)) + 0xb2 (ccl_msg)
  0x1ec36: __libc_start_main + 0xe6 (c)
End-trace
KennyTan_Altera
1) can you use the latest release of quartus Prime pro 19.2?
2) can you attached your design.qar files for us to investigate?
sstrell
Try quitting Quartus and throwing out the qdb folder in your project directory. Start Quartus again and try to recompile.
#iwork4intel
