17255 Discussions
VCS scripts to compile the Altera libraries
Does anyone have scripts in VCS to compile the Altera simulation libraries?
I'm not familiar with any specific scripts to set up the Altera libraries in VCS. However, I did find a useful design example on the Altera website:
http://www.altera.com/support/examples/vcs/exm-vcs-timing-verilog.html
Based on the TCL script that was provided, here's a snit it of the TCL file to setup your simulation:
vcs
# -R
# ## To invoke the GUI, use -RI option
-RI
# ## 64-bit version
# -full64
# ## record all the messages in a log file named test_net.log
-l test_net.log
# ## inlcude the path for libraries required for simulation
-v stratixii_atoms.v
# ## compile the test bench
test_multiplier.v
# ## inlcude the design files
multiplier.vo
# ## include these switches for transporting path delays and internal delays
# ## to get more information on these switches, refer to VCS Userguide
+transport_int_delays
+pulse_int_e/0
+pulse_int_r/0
+transport_path_delays
+pulse_e/0
+pulse_r/0
If you refer to the "include the path for libraries required for simulation", here's the command for adding the Stratix II device library for VCS simulation:
Not sure if this helps, but just my two cents.
-Pld_wiz
