VGA monitor display
Hi guys.
I am having problem about my VGA monitor. I already have output on my VGA monitor. But now I am confuse about the output. See my attachment for the output. Here is my coding for the VGA monitor for last part. I want to display color based on my rom. If the content in rom is "128"(decimal), it will display WHITE color on VGA monitor else black color. But now the output seems have something wrong. Sorry for my bad explaination. Anybody who got idea abot my problem. Thanks for your attention.
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY hw_image_generator IS
GENERIC(
pixels_y : INTEGER := 600; --row that first color will persist until
pixels_x : INTEGER := 600); --column that first color will persist until
PORT(
disp_ena : IN STD_LOGIC; --display enable ('1' = display time, '0' = blanking time)
column : IN INTEGER; --column pixel coordinate
row : IN INTEGER; --row pixel coordinate
red : OUT STD_LOGIC_VECTOR(7 DOWNTO 0) := (OTHERS => '0'); --red magnitude output to DAC
green : OUT STD_LOGIC_VECTOR(7 DOWNTO 0) := (OTHERS => '0'); --green magnitude output to DAC
blue : OUT STD_LOGIC_VECTOR(7 DOWNTO 0) := (OTHERS => '0'); --blue magnitude output to DAC
Q : in std_logic_vector (7 downto 0));
END hw_image_generator;
ARCHITECTURE behavior OF hw_image_generator IS
begin
PROCESS(disp_ena, row, column)
BEGIN
IF(disp_ena = '1') THEN
IF(row < pixels_y AND column < pixels_x) THEN
IF (Q = "10000000") THEN
red <= (OTHERS => '1');----white
green <= (OTHERS => '1') ;---white
blue <= (OTHERS => '1');---white
ELSE
red <= (OTHERS => '0');
green <= (OTHERS => '0') ;
blue <= (OTHERS => '0');
END IF;
ELSE
green <= (OTHERS => '0');
END IF;
ELSE
END IF;
END PROCESS;
END behavior;
The code you've posted looks (approximately) right. However, you've not posted the code that's responsible for the problem.
How do you generate the relative timing between the control signals and the RGB data going to your VGA device? You don't say what hardware you're using - is it a development board or your own? You must be generating horizontal & vertical sync signals as well. The issue is in the timing of these signals with respect to your column/row lookup for your colour data.
Cheers,
Alex
Your process is also missing the Q signal from the sensitivity list, so it will not function correctly in simulation.
Thanks Alex and Tricky for your feedback.
Here is my full digaram (attachment). And here is my full coding for vga controller. I am using altera de2 115 board.
LIBRARY ieee;
ENTITY vga_controller IS
GENERIC(
h_pulse : INTEGER := 136; --horiztonal sync pulse width in pixels
h_bp : INTEGER := 160; --horiztonal back porch width in pixels
h_pixels : INTEGER := 1024; --horiztonal display width in pixels
h_fp : INTEGER := 24; --horiztonal front porch width in pixels
h_pol : STD_LOGIC := '0'; --horizontal sync pulse polarity (1 = positive, 0 = negative)
v_pulse : INTEGER := 6; --vertical sync pulse width in rows
v_bp : INTEGER := 29; --vertical back porch width in rows
v_pixels : INTEGER := 768; --vertical display width in rows
v_fp : INTEGER := 3; --vertical front porch width in rows
v_pol : STD_LOGIC := '1'); --vertical sync pulse polarity (1 = positive, 0 = negative)
PORT(
pixel_clk : IN STD_LOGIC; --pixel clock at frequency of VGA mode being used
reset_n : IN STD_LOGIC; --active low asycnchronous reset
h_sync : OUT STD_LOGIC; --horiztonal sync pulse
v_sync : OUT STD_LOGIC; --vertical sync pulse
disp_ena : OUT STD_LOGIC; --display enable ('1' = display time, '0' = blanking time)
column : OUT INTEGER; --horizontal pixel coordinate
row : OUT INTEGER; --vertical pixel coordinate
n_blank : OUT STD_LOGIC; --direct blacking output to DAC
n_sync : OUT STD_LOGIC); --sync-on-green output to DAC
END vga_controller;
ARCHITECTURE behavior OF vga_controller IS
CONSTANT h_period : INTEGER := h_pulse + h_bp + h_pixels + h_fp; --total number of pixel clocks in a row
CONSTANT v_period : INTEGER := v_pulse + v_bp + v_pixels + v_fp; --total number of rows in column
BEGIN
n_blank <= '1'; --no direct blanking
n_sync <= '0'; --no sync on green
PROCESS(pixel_clk, reset_n)
VARIABLE h_count : INTEGER RANGE 0 TO h_period - 1 := 0; --horizontal counter (counts the columns)
VARIABLE v_count : INTEGER RANGE 0 TO v_period - 1 := 0; --vertical counter (counts the rows)
BEGIN
IF(reset_n = '0') THEN --reset asserted
h_count := 0; --reset horizontal counter
v_count := 0; --reset vertical counter
h_sync <= NOT h_pol; --deassert horizontal sync
v_sync <= NOT v_pol; --deassert vertical sync
disp_ena <= '0'; --disable display
column <= 0; --reset column pixel coordinate
row <= 0; --reset row pixel coordinate
ELSIF(pixel_clk'EVENT AND pixel_clk = '1') THEN
--counters
IF(h_count < h_period - 1) THEN --horizontal counter (pixels)
h_count := h_count + 1;
ELSE
h_count := 0;
IF(v_count < v_period - 1) THEN --veritcal counter (rows)
v_count := v_count + 1;
ELSE
v_count := 0;
END IF;
END IF;
--horizontal sync signal
IF(h_count < h_pixels + h_fp OR h_count > h_pixels + h_fp + h_pulse) THEN
h_sync <= NOT h_pol; --deassert horiztonal sync pulse
ELSE
h_sync <= h_pol; --assert horiztonal sync pulse
END IF;
--vertical sync signal
IF(v_count < v_pixels + v_fp OR v_count > v_pixels + v_fp + v_pulse) THEN
v_sync <= NOT v_pol; --deassert vertical sync pulse
ELSE
v_sync <= v_pol; --assert vertical sync pulse
END IF;
--set pixel coordinates
IF(h_count < h_pixels) THEN --horiztonal display time
column <= h_count; --set horiztonal pixel coordinate
END IF;
IF(v_count < v_pixels) THEN --vertical display time
row <= v_count; --set vertical pixel coordinate
END IF;
--set display enable output
IF(h_count < h_pixels AND v_count < v_pixels) THEN --display time
disp_ena <= '1'; --enable display
ELSE --blanking time
END IF;
END IF;
END PROCESS;
END behavior;
Have you simulated the code to ensure it produces the correct and expected behaviour?
