I am trying to read and write 8-bit Counter data Using Quartus and NIOS.
In SOPC : I am assigning PIO : 1-bit input for enable
PIO : 8-bit output for out
module Counter_Top_Level_design
input clk, rst_n,
output wire[7:0] out
wire enable;
always @ (posedge clk or negedge rst_n)
begin
if (~rst_n)
out <= 0;
else if (enable == 1'b1)
out <= out + 1;
end
NIOS_SYSTEM niosii_system_inst (
.clk_clk (clk ), // clk.clk
.reset_reset_n (rst_n ), // reset.reset_n
.output_pio_export ( enable ), // output_pio.export
.counter_out_export (out)
endmodule
I am getting an Error message :
Error (10137): Verilog HDL Procedural Assignment error at Counter_Top_Level_design.v(11): object "out" on left-hand side of assignment must have a variable data type
Error (10137): Verilog HDL Procedural Assignment error at Counter_Top_Level_design.v(13): object "out" on left-hand side of assignment must have a variable data type
output port "out" must have reg data type so replace "output wire[7:0] out" with "output reg[7:0] out"
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Best Regards
Vikas Jathar
(This message was posted on behalf of Intel Corporation)
input clk,
output reg[7:0] out
always @(posedge clk)
begin
out <= out + 1;
end
endmodule
I have assigned PIO (output):8 bit, its showing error. If i assign PIO (input):8 bit error not coming. But i want to read the counter data.
Have you resolved the issue?
If not, please provide the project file if possible.
Best Regards
Vikas Jathar
Hello, Instead of PIO. Now i am using AVALON On-chip FIFO Memory Core.
Still my issue have not solved. Please help me 😨
I am getting Proper answer
Sorry, I am not getting the result.
