Verilog Testbench
Does Altera Quartus II support Verilog testbench? If yes, how to run a Verilog testbench using QuartusII?
Suppose I have a 2 to 1multiplexer below:
module mux_2to1(Y, A, B, sel);
output [15:0] Y;
input [15:0] A, B;
input sel;
reg [15:0] Y;
always @(A or B or sel)
if (sel == 1'b0)
Y = A;
else
Y = B;
endmodule
A testbench is created as below:
`timescale 1ns / 100ps
module Test_mux_2to1;
wire [15:0] MuxOut; //use wire data type for outputs from instantiated module
reg [15:0] A, B; //use reg data type for all inputs
reg sel; // to the instantiated module
reg clk; //to be used for timing of WHEN to change input values
// Instantiate the MUX (named DUT {device under test})
mux_2to1 DUT(MuxOut, A, B, sel);
//This block generates a clock pulse with a 20 ns period
always
# 10 clk = ~clk;
//This initial block will provide values for the inputs
// of the mux so that both inputs/outputs can be displayed
initial begin
$timeformat(-9, 1, " ns", 6);
clk = 1’b0; // time = 0
A = 16'hAAAA; B = 16'h5555; sel = 1'b0;
@(negedge clk) //will wait for next negative edge of the clock (t=20)
A = 16'h0000;
@(negedge clk) //will wait for next negative edge of the clock (t=40)
sel = 1'b1;
@(negedge clk) //will wait for next negative edge of the clock (t=60)
B = 16'hFFFF;
@(negedge clk) //will wait for next negative edge of the clock (t=80)
A = 16'hA5A5;
@(negedge clk) //will wait for next negative edge of the clock (t=100)
sel = 1'b0;
@(negedge clk) //will wait for next negative edge of the clock (t=120)
$finish; // to shut down the simulation
end //initial
// this block is sensitive to changes on ANY of the inputs and will
// then display both the inputs and corresponding output
# 1 $display("At t=%t sel=%b A=%h B=%h MuxOut=%h",
$time, sel, A, B, MuxOut);
endmodule
How to test the multiplexer with the testbench using Quartus II?
Thank you
QII Simulator doesn't support testbench but Modelsim-Altera does. See the following related posts:
http://www.alteraforum.com/forum/showthread.php?t=983
http://www.alteraforum.com/forum/showthread.php?t=1066
