Does Altera Quartus II support Verilog testbench? If yes, how to run a Verilog testbench using QuartusII?
Suppose I have a 2 to 1multiplexer below: //********************************************************* module mux_2to1(Y, A, B, sel); //********************************************************* output [15:0] Y; input [15:0] A, B; input sel; reg [15:0] Y; always @(A or B or sel) if (sel == 1'b0) Y = A; else Y = B; endmodule A testbench is created as below: `timescale 1ns / 100ps //********************************************************* module Test_mux_2to1; //********************************************************* wire [15:0] MuxOut; //use wire data type for outputs from instantiated module reg [15:0] A, B; //use reg data type for all inputs reg sel; // to the instantiated module reg clk; //to be used for timing of WHEN to change input values // Instantiate the MUX (named DUT {device under test}) mux_2to1 DUT(MuxOut, A, B, sel); //This block generates a clock pulse with a 20 ns period always # 10 clk = ~clk; //This initial block will provide values for the inputs // of the mux so that both inputs/outputs can be displayed initial begin $timeformat(-9, 1, " ns", 6); clk = 1’b0; // time = 0 A = 16'hAAAA; B = 16'h5555; sel = 1'b0; @(negedge clk) //will wait for next negative edge of the clock (t=20) A = 16'h0000; @(negedge clk) //will wait for next negative edge of the clock (t=40) sel = 1'b1; @(negedge clk) //will wait for next negative edge of the clock (t=60) B = 16'hFFFF; @(negedge clk) //will wait for next negative edge of the clock (t=80) A = 16'hA5A5; @(negedge clk) //will wait for next negative edge of the clock (t=100) sel = 1'b0; @(negedge clk) //will wait for next negative edge of the clock (t=120) $finish; // to shut down the simulation end //initial // this block is sensitive to changes on ANY of the inputs and will // then display both the inputs and corresponding output always @(A or B or sel) # 1 $display("At t=%t sel=%b A=%h B=%h MuxOut=%h", $time, sel, A, B, MuxOut); endmodule How to test the multiplexer with the testbench using Quartus II? Thank youLink Copied
QII Simulator doesn't support testbench but Modelsim-Altera does. See the following related posts:
http://www.alteraforum.com/forum/showthread.php?t=983 http://www.alteraforum.com/forum/showthread.php?t=1066
