17259 Discussions
Verilog always blocks
Hi all,
So I'm a verilog beginner having just picked myself up a DE1 board to play with. Currently I am having issues with always blocks. Given this simple example:
module FirstProject (SW, LEDR); input SW; output LEDR; reg LEDR; reg counter = 3'b0; always (SW) //at symbol removed as forum thinks I'm trying to post a link begin counter = (counter + 1)% 4'b1000; LEDR = counter; end endmodule
My understanding is that the always block should only execute when a change in SW[0] occurs, but on the board the always block is continually executed resulting in all 3 LED's being lit.
If I change always (at) (SW[0])
to always (at) (posedge SW[0]) then things behave as expected and the LED's count upwards when the switch is toggled on.
So my question is why would the not behave as expected and only change each time the switch is toggled?
Any help would be appreciated.
Your question is quite right and actually indicates the misleading and poor description given around about otherwise powerful tools.
without posedge you are asking to have a counter that counts up without any waiting except for change of sw (which is not read in the block anyway and becomes only a simulation feature i.e. the actual hardware will ignore your condition of change of sw and will not build any logic connection to sw(as far as I know). There will be no register even though you declare a register, instead the design will latch the count value) so it is really always just a counter counting up at full silicon speed. with clock edge you are asking to build an actual wait for signal change and this translates to a clocked register waiting for your finger.
first statement will make it count as long as SW[0]==1
Would really recommend looking at the concepts of RTL coding. HDL languages like Verilog, VHDL need to be used in an RTL style of coding so that your design can be implemented in terms of gates & flops (LUTs for FPGAs). For this, there are coding guidelines to be followed when trying to infer different types of logic; these guidelines differ (slightly) from vendor to vendor.
Have a look at Altera's recommended coding styles in the below link:
http://www.altera.com/literature/hb/qts/qts_qii51007.pdf
I would recommend something like this instead:
always @ (posedge clk or posedge reset) begin if (reset == 1) begin counter <= 0; end else if (SW == 1) begin counter <= counter + 1; // assuming you want a counter that goes from 0 to 7 here, otherwise you would code this differently end end assign LEDR = counter; // make LEDR a wire instead of a reg
