17253 Discussions
Warning 12914 SignalTap file not embedded into sof
When compiling a project through Quartus Prime Lite IDE, I have no problem. I'm using a command-line batch file to automate the QSYS generation, compiling and programming all at once, but in the Assembler part of the compilation, when running from the batch file, I get the following warning :
"Warning (12914): The file, [...]/db/stp1_auto_stripped.stp, is not embedded into sof file as expected. Some tools, such as System Console, may not function fully."
The following command line is launched (from MATLAB) :
"C:\altera_lite\15.1\quartus\bin64\quartus_sh --flow compile [...].qpf');"
Any idea why launching the compilation process in the IDE includes the SignalTap file, but doesn't in the command-line process?
Thanks. I'm a beginner with Altera products.
JC
Sounds weird. You might want to try contact MySupport on this.
Thanks - I've sent a request and will post here if we have a solution for this.
Is there any update on the request you sent ?
