17268 Discussions
Warning Messages in conjunction with for PLLs
Hello together,
for a new design i want to generate different clocks:
50 MHz intern
125 MHz intern
125 MHz extern 180°
87,5 MHz intern
66 MHz extern
64,167 MHz intern/extern
The input clock of the FPGA is 50 MHz.
The target device is an Altera Cyclone IV-E FPGA with four integrated PLLs.
PLL2:
in: 50 MHz (from extern)
out0: 87,5 MHz intern
out1: 50 MHz intern
PLL1:
in: 50 MHz intern
out0: 125 MHz 180° extern
out1: 125 MHz intern
PLL3:
in: 50 MHz intern
out: 66 MHz extern
PLL4:
in: 50 MHz intern
out:64,167 MHz intern/extern
At first I want to know if it is correct how I cascade the PLLs?
Is it actually necessary to generate an intern 50 MHZ clock for PLL1, PLL3, PLL4?
After compiling I get some kinds of warning messages:
Warning Message Type1:
Warning: The parameters of the PLL PLL3:PLL3_inst|altpll:altpll_component|PLL3_altpll:auto_generated|pll1 and the PLL PLL4:PLL4_inst|altpll:altpll_component|PLL4_altpll:auto_generated|pll1 do not have the same values - hence these PLLs cannot be merged
Info: The values of the parameter "M" do not match for the PLL atoms PLL4:PLL4_inst|altpll:altpll_component|PLL4_altpll:auto_generated|pll1 and PLL PLL3:PLL3_inst|altpll:altpll_component|PLL3_altpll:auto_generated|pll1
Info: The value of the parameter "M" for the PLL atom PLL4:PLL4_inst|altpll:altpll_component|PLL4_altpll:auto_generated|pll1 is 77
Info: The value of the parameter "M" for the PLL atom PLL3:PLL3_inst|altpll:altpll_component|PLL3_altpll:auto_generated|pll1 is 33
Info: The values of the parameter "N" do not match for the PLL atoms PLL4:PLL4_inst|altpll:altpll_component|PLL4_altpll:auto_generated|pll1 and PLL PLL3:PLL3_inst|altpll:altpll_component|PLL3_altpll:auto_generated|pll1
Info: The value of the parameter "N" for the PLL atom PLL4:PLL4_inst|altpll:altpll_component|PLL4_altpll:auto_generated|pll1 is 6
Info: The value of the parameter "N" for the PLL atom PLL3:PLL3_inst|altpll:altpll_component|PLL3_altpll:auto_generated|pll1 is 5
Info: The values of the parameter "LOOP FILTER R" do not match for the PLL atoms PLL4:PLL4_inst|altpll:altpll_component|PLL4_altpll:auto_generated|pll1 and PLL PLL3:PLL3_inst|altpll:altpll_component|PLL3_altpll:auto_generated|pll1
Info: The value of the parameter "LOOP FILTER R" for the PLL atom PLL4:PLL4_inst|altpll:altpll_component|PLL4_altpll:auto_generated|pll1 is 12000
Info: The value of the parameter "LOOP FILTER R" for the PLL atom PLL3:PLL3_inst|altpll:altpll_component|PLL3_altpll:auto_generated|pll1 is 6000
Info: The values of the parameter "Min Lock Period" do not match for the PLL atoms PLL4:PLL4_inst|altpll:altpll_component|PLL4_altpll:auto_generated|pll1 and PLL PLL3:PLL3_inst|altpll:altpll_component|PLL3_altpll:auto_generated|pll1
Info: The value of the parameter "Min Lock Period" for the PLL atom PLL4:PLL4_inst|altpll:altpll_component|PLL4_altpll:auto_generated|pll1 is 19737
Info: The value of the parameter "Min Lock Period" for the PLL atom PLL3:PLL3_inst|altpll:altpll_component|PLL3_altpll:auto_generated|pll1 is 10150
Info: The values of the parameter "Max Lock Period" do not match for the PLL atoms PLL4:PLL4_inst|altpll:altpll_component|PLL4_altpll:auto_generated|pll1 and PLL PLL3:PLL3_inst|altpll:altpll_component|PLL3_altpll:auto_generated|pll1
Info: The value of the parameter "Max Lock Period" for the PLL atom PLL4:PLL4_inst|altpll:altpll_component|PLL4_altpll:auto_generated|pll1 is 30864
Info: The value of the parameter "Max Lock Period" for the PLL atom PLL3:PLL3_inst|altpll:altpll_component|PLL3_altpll:auto_generated|pll1 is 20408
Warning Message Type2:
Warning: The input ports of the PLL PLL2:PLL2_inst|altpll:altpll_component|PLL2_altpll:auto_generated|pll1 and the PLL PLL4:PLL4_inst|altpll:altpll_component|PLL4_altpll:auto_generated|pll1 are mismatched, preventing the PLLs to be merged
Warning: PLL PLL2:PLL2_inst|altpll:altpll_component|PLL2_altpll:auto_generated|pll1 and PLL PLL4:PLL4_inst|altpll:altpll_component|PLL4_altpll:auto_generated|pll1 have different input signals for input port ARESET
Warning Message Type3:
Warning: PLL "PLL4:PLL4_inst|altpll:altpll_component|PLL4_altpll:auto_generated|pll1" input clock inclk[0] is not fully compensated and may have reduced jitter performance because it is fed by a non-dedicated input
Info: Input port INCLK[0] of node "PLL4:PLL4_inst|altpll:altpll_component|PLL4_altpll:auto_generated|pll1" is driven by ClkCtrl:ClkCtrl_inst2|ClkCtrl_altclkctrl_7ji:ClkCtrl_altclkctrl_7ji_component|wire_clkctrl1_outclk which is OUTCLK output port of Clock control block type node ClkCtrl:ClkCtrl_inst2|ClkCtrl_altclkctrl_7ji:ClkCtrl_altclkctrl_7ji_component|clkctrl1
Warning Message Type4:
Warning: PLL "PLL4:PLL4_inst|altpll:altpll_component|PLL4_altpll:auto_generated|pll1" output port clk[0] feeds output pin "DviOClk~output" via non-dedicated routing -- jitter performance depends on switching rate of other design elements. Use PLL dedicated clock outputs to ensure jitter performance
Warning Message Type5:
Warning: PLL "PLL3:PLL3_inst|altpll:altpll_component|PLL3_altpll:auto_generated|pll1" output port clk[0] feeds output pin "Clk_66_E6_0~output" via non-dedicated routing -- jitter performance depends on switching rate of other design elements. Use PLL dedicated clock outputs to ensure jitter performance
Could someone help me to solve the problems?
BR,
Carsten
Hi cchabrie,
I received the same error after I turned on a number of synthesis options recommended to me by the Optimization Advisor.
I think the trigger for it may be one of these synthesis options:
Perform WYSIWYG Primitive Resyntheis=ON
Remove Redundant Logic Cells=ON
Perform Register Duplication for Performance=OFF
These were OFF, OFF, and On respectively in my design and when I changed them I got this warning.
I don't think this warning is a problem because I think it is telling you it is trying to merge logic functions between two PLLs, but found parameters with each PLL that prevented them from being merged. If the PLLs have different parameters we wouldn't want them merged anyway...right?
-Sean
What MegaFunctions or MegaCores are you implementing that are trying to merge PLLs?
True LVDS resources have PLL restrictions per side (Left / Right). Are you using the LVDS Serdes/DPA?
Hi Sean,
thank you for the hints. I don't want to merge PLLs. This is why I disable "Auto Merge PLLs" in the "Fitters Settings". With disabling this option, the are less warnings. But there are still two kinds of warnings:
Type 1:
Warning: PLL "PLL4:PLL4_inst|altpll:altpll_component|PLL4_altpll:auto_generated|pll1" input clock inclk[0] may have reduced jitter performance because it is fed by a non-dedicated input
Type 2:
Any ideas to remove this warnings??
Thank you
Br, Carsten
@fpgaGuy: I use the megafunction "ALTPLL".
Carsten,
Without knowing more about the I/O IP and clocking architecture implementation it is difficult to say precisely what the issues are, but...
It looks to me like you have three issues:
1. Resource contention.
Two PLLs instantiated in the RTL are competing for the same resource in the silicon. This can happen with multiple ALTLVDS or transceivers when instances since there are dedicated clocks for them. Warning Message Type 1 makes this clear.
**Warning Message Type1: Warning: The parameters of the PLL [x] and the PLL [x] do not have the same values - hence these PLLs cannot be merged
2. Incorrect MegaFunction I/O connections.
Warning Messages of Type 2 indicate there are different sources (pins, registers, clock routing) for 2 separately instantiated PLL inputs.
**Warning Message Type2: Warning: The input ports of the PLL [A] and the PLL [B] are mismatched, preventing the PLLs to be merged
Warning: PLL [C] and PLL[D] have different input signals for input port ARESET
3. Using normal routing for clocks instead of dedicated clock routing.
This probably means the clock is passing through logic - it's not just connected to clock ports of PLLs, registers, RAMs, etc. That degrades performance and generally is not good design practice. Don't do this unless you REALLY must.
**Warning Message Type3: Warning: PLL [D] is not fully compensated and may have reduced jitter performance because it is fed by a non-dedicated input
**Warning Message Type4: Warning: PLL [E] output port clk[0] feeds output pin "DviOClk~output" via non-dedicated routing -- jitter performance depends on switching rate of other design elements. Use PLL dedicated clock outputs to ensure jitter performance
**Warning Message Type5: Warning: PLL [F] feeds output pin "Clk_66_E6_0~output" via non-dedicated routing -- jitter performance depends on switching rate of other design elements. Use PLL dedicated clock outputs to ensure jitter performance
Good luck,
Mike
P.S. Have you tried using MySupport?
What are the interfaces or protocols at the I/O that are getting these warnings?
Please describe, preferably with a diagram, what your clocking architecture looks like. What is every element in the clocks' paths from pin, to PLL, to registers, RAMs, etc?
Hello fpgaGuy,
there is only one kind of error message left. An explanation follows at the end of this thread.
explanation:
FPGA: Cyclone IV E - EP4CE115F23I7
Deticated Input Clock Pin of the FPGA: Pin A12 = CLK8
-- First PLL
PLL2_inst : PLL2
PORT MAP (
areset => ResSys,
inclk0 => CLK, -- 50 MHz
c0 => Clk_50_E6_0_Pre, -- 50 MHz --> Clock Control Block
c1 => Clk_87_5_E6_0, -- 87,5 MHz
locked => PLL2_Locked
Clock Control Block
ClkCtrl_inst2 :
ClkCtrl PORT MAP ( inclk => Clk_50_E6_0_Pre,
outclk => Clk_50_E6_0
Second PLL
PLL1_inst : PLL
PORT MAP (
areset => PLL2_Locked,
inclk0 => Clk_50_E6_0, -- 50MHz
c0 => Clk_125_E6_180, -- 125 MHz/ 180°
c1 => Clk_125_E6_0, -- 125 MHz/ 0°
locked => PLL1_Locked
Third PLL
PLL4_inst : PLL4
PORT MAP (
inclk0 => Clk_50_E6_0, -- 50 MHz
c0 => Clk_64_166667_E6_0, -- 64,16667 MHz/ 0°
locked => PLL4_Locked
Any idea what`s the reason for the warning message?
BR,
Carsten
Hey, Carsten,
That means the source of the PLL's input clock is from a sub-optimal location or primitive. I'd guess you have a transceiver or serdes reference clock connected to a sub-optimal pin. It could also be that you're trying to use a PLL output clock to feed a PLL that's meant to be fed directly from a dedicated reference clk pin, or at least a suitable, nearby dedicated clk input pin.
