17255 Discussions
Warning: Timing-driven synthesis is skipped because there are multiple hierarchies in
When compiling my design i get the following warings.
Warning: Timing-driven synthesis is skipped because there are multiple hierarchies in the design
Warning: Timing-driven synthesis is skipped because it could not initialize the timing netlist
I think this is the reason I am getting some timing issues with my design.
What does it mean and how do I fix it.
All help would be appreciated.
--- Quote Start ---
--- Quote End ---
looks strange. Are you using design partitions ? Is the SDC file in the project included?
Which device are you using ?
Kind regards
GPK
Thanks for you reply.
I am using a stratixIII device.
I dont think the project has any design partitions but it has 4 SDC files, to cover different parts of the design.
--- Quote Start ---
--- Quote End ---
I forgot there is a similar thread in the forum :
http://www.alteraforum.com/forum/showthread.php?t=6117
DrJohn issued a service request and got the answer that the problem could be caused by
failing constraints in the SDC file. Have a look to the thread, maybe it helps. Otherwise I
would recommend to issue a service request again.
Kind regards
GPK
