17266 Обсуждение
Warning: (vsim-3473) Component instance "mem_map : system_mem" is not bound.
ahmedhs
Начинающий
1 535Просмотр.
Hello
I was simulating my project and got this warning.
I checked the "mem_map : system_mem" in the testbench and couldn't find the problem.
I uploaded the testbench and system_mem.
Hopefully you can help me.
0 баллов
3 Ответы
ShengN_Intel
Сотрудник
1 510Просмотр.
I try to compile and simulate the design files you attached. However, I can't access to work.keccak_globals as you didn't provide the library file.
I notice both component and entity names are same (system_mem) should be not a problem. May be you can try in testbench like below:
 for mem_map : system_mem use entity work.system_mem;
begin
mem_map : system_mem port map(clk,rst_n,enR_mem,enW_mem,addr_mem,data_to_mem_mem,data_from_mem);
OR
begin
mem_map : entity work.system_mem port map(clk,rst_n,enR_mem,enW_mem,addr_mem,data_to_mem_mem,data_from_mem);
May also take a look at this:
Component Not Bound
Symptoms:
   - Warning: (vsim-3473) Component instance "fifo_receiver : fifo" is not bound.
   - Signals coming in from a component remain unsigned.
Causes:
 When simulating, a component used in the design could not be found.
Solution:
   - Ensure that the component declaration matches the entity declaration exactly in the component file.
   - Ensure all files needed for the design have been compiled.
   - Check to make sure your directories are what you think they are and that your files are all in the same directory.
   - In a few cases, a component might be optimized out during the simulation causing this error. If everything about appears right, simulate with the -novopt command.
**May check on this link at the component declaration section as well.
Sheng
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution and give Kudos.
ShengN_Intel
Сотрудник
1 489Просмотр.
May I know any further update or consideration?
Does the suggestion provided above help in resolving the problem? Thank you.
Sheng
ShengN_Intel
Сотрудник
1 465Просмотр.
Since there are no further feedback for this thread, I shall set this thread to close pending. If you still need further assistance, you are welcome reopen this thread within 20days or open a new thread, some one will be right with you. Thank you!
Ответить
