17268 Discussions
What is the most efficient way to configure different weak pull ups for the same design to create different bitstreams?
KAthu
I have a verilog design. I am trying create several different bitstreams from it, say 3. The only difference in those bit streams will be, which pins have weak pull-ups.
I know that one way to do this is to keep 3 revisions of the design and compile each separately.
Is there a more efficient way? Is there a way to synthesize and do the placement and fitting once for the whole design and then somehow link which pins should activate their weak-pullups to create 3 different bitstreams?
Thank you.
YuanLi_S_Intel
Hi Kasun,
No, you will need to reprogram in order to change the setting of weak pull ups on diff pins.
Thank You.
