17267 Discussions
Translating to Verilog and compiling Maxplus2 .bdf examples
CFabr1
Hi all,
I'm trying to translate to Verilog some Maxplus2 examples (in .bdf format) of TTL gates but I get some errors when compiling.I'm using Quartus 12.1
For example, this is the generated Verilog from the 7474.bdf file :
/ Copyright (C) 1991-2012 Altera Corporation
// Your use of Altera Corporation's design tools, logic functions
// and other software and tools, and its AMPP partner logic
// functions, and any output files from any of the foregoing
// (including device programming or simulation files), and any
// associated documentation or information are expressly subject
// to the terms and conditions of the Altera Program License
// Subscription Agreement, Altera MegaCore Function License
// Agreement, or other applicable license agreement, including,
// without limitation, that your use is for the sole purpose of
// programming logic devices manufactured by Altera and sold by
// Altera or its authorized distributors. Please refer to the
// applicable agreement for further details.
// PROGRAM      "Quartus II 64-Bit"
// VERSION      "Version 12.1 Build 177 11/07/2012 SJ Web Edition"
// CREATED      "Thu Apr 09 22:15:40 2020"
module \7474 (
   2CLRN,
   2CLK,
   2D,
   2PRN,
   1CLRN,
   1CLK,
   1D,
   1PRN,
   1Q,
   1QN,
   2Q,
   2QN
input wire   2CLRN;
input wire   2CLK;
input wire   2D;
input wire   2PRN;
input wire   1CLRN;
input wire   1CLK;
input wire   1D;
input wire   1PRN;
output wire   1Q;
output wire   1QN;
output wire   2Q;
output wire   2QN;
reg   DFF_10;
reg   DFF_9;
assign   1Q = DFF_9;
assign   2Q = DFF_10;
always@(posedge 2CLK or negedge 2CLRN or negedge 2PRN)
begin
if (!2CLRN)
   begin
   DFF_10 <= 0;
   end
else
if (!2PRN)
   begin
   DFF_10 <= 1;
   end
else
   begin
   DFF_10 <= 2D;
   end
end
assign   2QN = ~DFF_10;
assign   1QN = ~DFF_9;
always@(posedge 1CLK or negedge 1CLRN or negedge 1PRN)
begin
if (!1CLRN)
   begin
   DFF_9 <= 0;
   end
else
if (!1PRN)
   begin
   DFF_9 <= 1;
   end
else
   begin
   DFF_9 <= 1D;
   end
end
endmodule
When I try to compile it I get the errors in the attached snapshot.I'm able to compile Verilog code generated from most of the .bdf examples (like 74157.bdf).Any ideas why I get errors when compiling Verilog code generated from this 7474.bdf Maxplus2 example ?Thanks in advance.
ak6dn
Valued Contributor III
Port and signal names cannot start with a digit. The name must be escaped when used (ie, change 2CLK to \2CLK AND add a trailing space after the name).
So for example 'input wire 2CLRN;' becomes 'input wire \2CLRN ;' etc.
CFabr1
Thanks for reply.I changed the syntax in this way and I got less errors (snapshot attached)
// Copyright (C) 1991-2012 Altera Corporation
// CREATED      "Fri Apr 10 21:19:39 2020"
module \7474 (
   2CLRN,
   2CLK,
   2D,
   2PRN,
   1CLRN,
   1CLK,
   1D,
   1PRN,
   1Q,
   1QN,
   2Q,
   2QN
input wire   \2CLRN ;
input wire   \2CLK ;
input wire   \2D ;
input wire   \2PRN ;
input wire   \1CLRN ;
input wire   \1CLK ;
input wire   \1D ;
input wire   \1PRN ;
output wire   \1Q ;
output wire   \1QN ;
output wire   \2Q ;
output wire   \2QN ;
reg   DFF_10;
reg   DFF_9;
assign   1Q = DFF_9;
assign   2Q = DFF_10;
begin
if (!2CLRN)
   begin
   DFF_10 <= 0;
   end
else
if (!2PRN)
   begin
   DFF_10 <= 1;
   end
else
   begin
   DFF_10 <= 2D;
   end
end
begin
if (!1CLRN)
   begin
   DFF_9 <= 0;
   end
else
if (!1PRN)
   begin
   DFF_9 <= 1;
   end
else
   begin
   DFF_9 <= 1D;
   end
end
endmodule
ak6dn
Ok, maybe I was not being clear enough. ANYWHERE a non-standard format identifier (ie, starting with an alphabetic, and then containing only alphabetic, numeric, or underscore) is used it MUST be escaped. So in your above code, the identifiers in the module port list, in the assign statements, and those in equations in the always blocks need escaping. Here is what your code should look like:
module \7474 ( \2CLRN , \2CLK , \2D , \2PRN , \1CLRN , \1CLK , \1D , \1PRN , \1Q , \1QN , \2Q , \2QN );   input wire \2CLRN ; input wire \2CLK ; input wire \2D ; input wire \2PRN ; input wire \1CLRN ; input wire \1CLK ; input wire \1D ; input wire \1PRN ; output wire \1Q ; output wire \1QN ; output wire \2Q ; output wire \2QN ;   reg DFF_10; reg DFF_9;   assign \1Q = DFF_9; assign \2Q = DFF_10;   always @(posedge \2CLK or negedge \2CLRN or negedge \2PRN ) begin if (!\2CLRN ) begin DFF_10 <= 0; end else if (!\2PRN ) begin DFF_10 <= 1; end else begin DFF_10 <= \2D ; end end   assign \2QN = ~DFF_10; assign \1QN = ~DFF_9;   always@(posedge \1CLK or negedge \1CLRN or negedge \1PRN ) begin if (!\1CLRN ) begin DFF_9 <= 0; end else if (!\1PRN ) begin DFF_9 <= 1; end else begin DFF_9 <= \1D ; end end   endmodule
SyafieqS
Hi Caius,
According to your Verilog code, you are using first character for your identifier in module,port,signal assignment and statement equation with number. Either you change to new name for identifier or put ("\") if you want to keep the identifier naming. This is a escaped identifier as it allow for any printable ASCII character to be included in the name. Escaped identifiers begin with white space. The backslash (“\”) character leads off the identifier, which is then terminated with white space. The leading backslash character is not considered part of the identifier.
Thus in your program,
module \7474 (
  \2CLRN ,
  \2CLK ,
  \2D ,    /* port identifer declaration put "\" */
  \2PRN ,
  \1CLRN ,
  \1CLK ,
  \1D ,
  \1PRN ,
  \1Q ,
  \1QN ,
  \2Q ,
  \2QN
input wire  \2CLRN ;
input wire  \2CLK ;
input wire  \2D ;
input wire  \2PRN ;
input wire  \1CLRN ;      /* signal assingment put "\" */
input wire  \1CLK ;
input wire  \1D ;
input wire  \1PRN ;
output wire  \1Q ;
output wire  \1QN ;
output wire  \2Q ;
output wire  \2QN ;
reg  DFF_10;
reg  DFF_9;
assign  \1Q = DFF_9;
begin
if (!\2CLRN )
  begin
  DFF_10 <= 0;
  end
else
if (!\2PRN )
  begin
  DFF_10 <= 1;
  end
else
  begin
  DFF_10 <= \2D ;      /* statement all identifier put "\" */
  end
end
begin
if (!\1CLRN )
  begin
  DFF_9 <= 0;
  end
else
if (!\1PRN )
  begin
  DFF_9 <= 1;
  end
else
  begin
  DFF_9 <= \1D ;
  end
end
endmodule
CFabr1
Many thanks for suggestions and help, I'm now able to successfully compile.Last thing : is there a way to convert schematics drawn with EDA softwares (ike Kicad) to Verilog compatible with Quartus?I could draw schematics block in Quartus and then convert to Verilog but it's a pain.Thanks in advance.
ak6dn
You miight try this: https://github.com/efarres/KiCad-HDL
It has several netlist translator plugins for KiCad that can translate the intermediate XLST format to various other formats (verilog and vhdl in particular).
I have not used this translation tool in particular (but I do use KiCAD for PCB schematics). The generated verilog should be pretty vanilla format.
CFabr1
Thanks for reply.I tried in the past this plugin and found that the Verilog translation is not yet implemented, only VHDL is supported although still bugged according to the author.I attach a snapshot of what he said about.Snapshot.jpg
SyafieqS
Hi Caius,
You can actually use Quartus to do that, conversion from schematic to HDL (Verilog/VHDL).
CFabr1
Yes, I know.The problems is that I have all my schematics done in Kicad (some are very big) and translating them to Quartus would be a huge job also because the schematics entry in Quartus is not really user-friendly and intuitive.
