17252 Discussions
Why no recovery paths were found?
In TimeQuest Clock Transfer folder, I can see that there are 720 RR paths from CLKA to CLKB. But when I try to make timing report about these paths, it told me that no recovery paths were found. WHY??
There are probably no synchronized reset paths that originate in the CLKA domain but reset registers in the CLKB domain…which is most likely a good thing :-) I would guess there are 720 setup (data) paths between these domains.
Are you sure you're looking at Recovery Paths? RR usually means Rising to Rising transfers, which would show up in setup/hold analysis.
I don't think that my system has 720 RR paths from CLKA to CLKB, but timequest reports that. So I just to confirm whose are these paths, but it tells me no recovery paths found as well as removal paths, setup paths and hold paths.
I can't do much more without the design(perhaps some screenshots, but not sure if that will show what's going on or not.) I would trust the report_timing reports more than the Clock Transfer reports, but you may want to file an SR or something if you don't get to the bottom of it.
The screenshots shows below, hope it could help:
http://blogimg.chinaunix.net/blog/upfile2/080114111512.jpg
You just have a single report_timing with the -recovery option shown. What happens if you run the same command(up arrow) and change this to -setup?
Yes, if change it to -setup, it will report setup paths timing.
But I am confused that TimeQuest report there exist 720 recovery path but not setup paths.
Yeah, I missed that it was a Recovery Transfer report. Strange. You probably want to file an SR, as it doesn't make sense to me. (You could try making an .sdc file without any set_false_path or set_clock_group assignmnets and run the same commands with that. Maybe the Clock Transfers report is looking at false paths while the report_timing definitely does not.)
Yeah, you are correct.
set_false_path is the root reason.
Sorry for the stupid question.
Thanks!
That still seems odd. As you can see in your screenshot, even false-path transfers get listed. They just have "false path" instead of a number in the table.
I thought of a possible explanation for what bothered me in my previous post, but I didn't test it to see whether TimeQuest works this way.
Maybe for the transfer table to say "false path", the false-path has to be done from clock domain to clock domain instead of another way like from a particular source register to a particular destination register. If that's the case and paths that are false because of "set_false_path -from src_reg -to dst_reg" get listed in the transfer table with a number (even if all paths on the row of the table are actually false), then it would make sense that you could have all 720 paths in question cut with a register-to-register false-path exception, keeping report_timing from listing anything even though the transfer table doesn't say "false".
Yes, based on my study, your description is quite precise. :)
