17266 Discussions
Why won't the altera floating point add sub ip synthesize?
PEgan
Tried including the altfp_add_sub ip core in my project but cannot synthesize it. Each time I attempt to do so I get the following message:
'Error (12006): Node instance "altfp_add_sub_component" instantiates undefined entity "altfp_add_sub". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.'
I have made no modifications to the output of the IP catalog. I am currently running Quartus 19.1 on Arch Linux
PEgan
Turns out the design won't synthesize because I am using the free web edition of Quartus 19.1, while this IP is only available in the standard and pro editions. This is a bit confusing considering I am still prompted with the option to add Altera Floating Point IP. What makes this even more frustrating that I was only able to discover this after searching through the Floating point IP core documentation which itself isn't immediately available unless you go searching for it online.
PEgan
