17255 Discussions
Wireless Transmission using Cyclone II FPGA (Verilog HDL)
The data that is to sent out from the FPGA is in 8-bit form.
Whereas the encoder on the transmitter circuitry can only receive 4 bits.
Different coding have been tried but it just does not seem to work.
Anyone has done something similar before? Or is there any sample codings for this? Thanks! :)
Please describe your problem a little bit more concrete?
What is the purpose of your design?
Are you making a Radio Transceiver?
What do you do with the 8 bits output and 4 bits input?
What is your setup?
What is your coding?
What is it that you want to know?
data that is to be sent from the DE1 board is ASCII codes and morse codes
whereas the encoder only has 4 data pins
how to divide the 8-bit data into 4-bit so that it can be sent twice?
and what about the receiver part?
how to store the received data and combine it again into the 8-bit data?
What physical medium are you targeting with your "Wireless Transmission"? Is this sound, infra-red, light, RF or what???
For splitting up 8 bits into two 4 bit words you should simply take the first 4 bits and then the last four bits.
e.g.
... reg output_data; wire first_four, last_four; assign first_four = output_data; assign last_four = output_data; ...
I'm using RF transmission.
The data is in ASCII code form, which is 8-bit per data.
I now have to separate the 8-bit into 2 four-bits, so that the first 4 bits (LSB) is sent.
Then it will be followed by the other 4 bits (MSB).
But I have tried it using LEDs first.
Once a key is pressed, sometimes the MSB will be received first.
Sometimes, the LSB will be received first.
And, only second time of the key press will trigger the LEDs to change.
Why is it so?
sickmuse:
What kind of RF are you using? What frequency? What modulation (ASK, PSK,..), What standard (Bluetooth, Zigbee...)?
How are you replacing the RF link with LEDs?
To enable members of the forum to help you with this problem, you should be more specific and/or provide the code that does not do what you want it to do.
RF frequency 433.92 MHz
Modulation: FSK
I'm connecting the 4 data pins of the decoder at the receiver side to 4 LEDs.
this is the code for receiver side:
module receive_testing
# (parameter W_SIZE = 2) // 2^W_SIZE word in FIFO
(clk, reset, from_expansion, LED);
input clk, reset;
input [3:0] from_expansion;
output wire [7:0] LED;
reg write_code;
wire full_code, read_code;
reg [7:0] data_out_reg;
wire write_enable, write_disable;
wire [7:0] data_out_next;
fifo# (.B(8), .W(W_SIZE)) fifo_block_unit
(.clk(clk),
.reset(reset),
.write(write_code),
.read(read_code),
.write_data(from_expansion),
.read_data(data_out_next),
.empty(write_enable),
.full());
always @(posedge clk)
if (reset)
data_out_reg = 0;
else
data_out_reg <= data_out_next;
always@*
begin
if(from_expansion)
write_code <= 1;
else
write_code <= 0;
end
assign LED = data_out_reg;
assign read_code = ~write_code;
endmodule
module fifo
# (parameter B=8, W=4)
(clk, reset, read, write, write_data, read_data, empty, full);
input clk, reset, read, write;
input wire [B-1:0] write_data;
output empty, full;
output wire [B-1:0] read_data;
// signal declaration
reg [B-1:0] array_reg [2**W-1:0];
reg [W-1:0] write_reg, write_next, write_done;
reg [W-1:0] read_reg, read_next, read_done;
reg full_reg, empty_reg, full_next, empty_next;
wire write_enable;
// body
// register file write operation
if (write_enable)
array_reg[write_reg] <= write_data;
// register file read operation
assign read_data = array_reg[read_reg];
// write enabled only when FIFO is not full
assign write_enable = write & ~full_reg;
// fifo control logic
// register for read and write pointers
always @(posedge clk, posedge reset)
if (reset)
begin
write_reg <= 0;
read_reg <= 0;
full_reg <= 1'b0;
empty_reg <= 1'b1;
end
else
begin
write_reg <= write_next;
read_reg <= read_next;
full_reg <= full_next;
empty_reg <= empty_next;
end
// next-state logic for read and write pointers
always @*
begin
// successive pointer values
write_done = write_reg + 1;
read_done = read_reg + 1;
// default: keep old values
write_next = write_reg;
read_next = read_reg;
full_next = full_reg;
empty_next = empty_reg;
case ({write, read})
//2'b00: no options
2'b01: // read
if (~empty_reg)
begin
read_next = read_done;
full_next = 0;
if (read_done==write_reg)
empty_next = 1;
end
2'b10: // write
if (~full_reg)
begin
write_next = write_done;
empty_next = 0;
if (write_done==read_reg)
full_next = 1;
end
2'b11: //read and write
begin
write_next= write_done;
end
endcase
end
// output
assign full = full_reg;
assign empty = empty_reg;
endmodule
This is another example codings we've written:
module testing_wed2 (data_in, data_out);
input [7:0] data_in;
output wire [3:0] data_out;
reg lsb_enable;
wire msb_enable;
always@*
begin
if(data_in)
lsb_enable <= 1;
else
lsb_enable <= 0;
end
lsbmo lsbmo_controller_block_unit
(.data_inl(data_in),
.lsb_enable(lsb_enable),
.msb_enable(msb_enable),
.data_outl(data_out));
msb msb_controller_block_unit
(.data_inm(data_in),
.data_outm(data_out));
endmodule
module lsbmo(
input [7:0] data_inl,
input lsb_enable,
output reg [3:0] data_outl ,
output reg msb_enable );
always@*
begin
if(lsb_enable)
data_outl = data_inl[3:0];
msb_enable <= 1;
end
endmodule
module msb(
input msb_enable,
input [7:0] data_inm,
output reg [3:0] data_outm
always@*
begin
if(msb_enable)
data_outm = data_inm [7:4];
end
endmodule
Error: Net "data_out[3]~0", which fans out to "data_out[3]", cannot be assigned more than one value
Error: Net is fed by "lsbmo:lsbmo_controller_block_unit|data_outl[3]"
Error: Net is fed by "msb:msb_controller_block_unit|data_outm[3]"
Errors cannot be understood.
First some things that I do not understand from your design:
1) I do not understand why you are using this fifo for this project.
2) When all 4 bits of from_expansion are "0" you are emptying the fifo with reads.
3) On every "clk" clock cycle, when "from_expansion" is different from zero you will read in a new "from_expansion" in your fifo. In my opinion this can give rise to two problems:
  1. When the data from your RF receiver last longer than the amount of words in your fifo, the fifo will be full. This gets unnoticed in your design.
  2. What happens when you have transitions in your "from_expansion" signal between one state and the other? For example a change from: "1011" to "1100" could for example go over a number of clock cycles from "1011" to "1001" to "1101" to "1100". If such transitions from your 433 MHz receiver take longer than the clock period of your design, then they are all registered as separate values.
--- Quote Start ---
--- Quote End ---
Do you take into account the "full" and "empty" signals in your design. Whenever your fifo gets full, it will not read new data. So this could explain the strange behavior.
--- Quote Start ---
Why is it so?
--- Quote End ---
This is probably caused by the length of your fifo.
If I don't use FIFO at the receiver side
then what should I add in to make it works?
what about another coding I have posted up?
sickmuse...
can you sent me a link for example design of wireless transmission using rf
