17268 Discussions
access environmental variables in _hw.tcl files
Hello all,
When I try to print an environmental variables in the Quartus TCL Console (e.g. puts $::env(PATH) ) it works, but whenever I try to access it within a _hw.tcl component script it doesn't and I get the following error during elaboration:
Can't read "::env(PATH)": no such element in array
Could anyone shed some light on this?
Thank you.
I found the same issue, but never had time to look into it much further.
The following command might be useful to you to use as a work around (if all you want is the path to the _hw.tcl file):
set path_to_script ]]
where 'info script' gives you the _hw.tcl file, 'file normalize' gives you the full path to that script, and 'file dirname' strips off the _hw.tcl name.
At that point, you can use names relative to the _hw.tcl location.
Cheers,
Dave
Dear Dave,
Thank you for your reply. However, I want to reference the path of a separate file (not the TCL script) in order to add it with the add_fileset_file command. Using a path relative to the location of the TCL script would work, but would not be elegant at all since the file to be added is several layers of hierarchy away.
I will probably submit a service request with Altera.
--- Quote Start ---
--- Quote End ---
That was the situation I was also faced with. It would be nicer if the Tcl interpreter preserved the environment variables, but it doesn't.
--- Quote Start ---
--- Quote End ---
Please post their response here.
I'd like to see a more elegant solution too :)
Cheers,
Dave
This is fixed in Quartus 13.0 as far as I can see.
--- Quote Start ---
--- Quote End ---
Awesome, thanks for posting :)
Cheers,
Dave
After some further testing I concluded that this was already fixed from Quartus/Qsys 12.1 onwards.
The solution is that you need to use the correct package command that forces the component to be interpreted by the latest version of Qsys (and not SOPC Builder, for which reading environment variables doesn't work).
For example, change the package command in your TCL file from e.g.:
package require -exact sopc 11.0
to either:
package require -exact qsys 12.1
or
package require -exact qsys 13.0
depending on the Quartus version you are using.
