17249 Discussions
aoc compile error: using host channel feature
I am writing a simple OpenCL code for testing host channel feature introduced 17.1.
The code is as follows:
# pragma OPENCL EXTENSION cl_intel_fpga_host_pipe : enable kernel void clkernel( __attribute__((intel_host_accessible)) __read_only pipe ulong4 cl_input, __attribute__((intel_host_accessible)) __write_only pipe ulong4 cl_output) { ulong4 val; while( 1 ) { if( read_pipe(cl_input, &val)) { while( !write_pipe(cl_output, &val) ) ; } } }
when compiling the code by aoc, error message was printed like this.
$ which aoc
/cad/intelFPGA/17.1/hld/bin/aoc
$ aoc clkernel.cl
aoc: Running OpenCL parser....
clkernel.cl:1:26: warning: unknown OpenCL extension 'cl_intel_fpga_host_pipe' - ignoring# pragma OPENCL EXTENSION cl_intel_fpga_host_pipe : enable
1 warning generated.
aoc: Optimizing and doing static analysis of code...
Error: Channel has no point connection: ID= host_to_dev
avm_channel_id_host_to_dev_read connection missing, or optimized away
Error: Could not write system script to file. System generation aborted!
Error: System integrator FAILED.
Refer to clkernel/clkernel.log for details.
What should I do next?
I did a test and this doesn't work for me either. Probably some bug in the tool chain. I recommend opening a support ticket directly with altera.
HRZ,
Thank you for you advise.
I will open a ticket to report this situation.
May I know are you using the dedicated BSP(a10gx_hostch) for this feature compilation?
Board list:
a10gx
Board Package: C:\intelFPGA_pro\17.1\hld\board\a10_ref
a10gx_hostch
Channels: host_to_dev, dev_to_host
CloseCL
(This message was posted on behalf of Intel Corporation)
--- Quote Start ---
Board list:
a10gx
a10gx_hostch
CloseCL
--- Quote End ---
The target BSP does not make any difference here since the compiler ignores the host channel extension all together because it is unknown to it. Either the name of the extension is something other than what is written in Altera's documents, or support for the extension is broken.
--- Quote Start ---
Board list:
a10gx
a10gx_hostch
CloseCL
--- Quote End ---
Thank you for your advice.
There are no errors when using the BSP 'a10gx_hostch',
but the warning described below are remained.
Anyway, the compilation of the design is finished successfully.
