array problem
Hello I'm trying to migrate from quartus 5.1 to 9.0 sp2. The problem I have is that 9.0 generates much more elements (11,000 instead of 5,000) than 5.1. And it all happens because of this code.
usb_data : PROCESS(ds) is
TYPE RAM is array (0 to 255) of unsigned(15 downto 0);
variable config :RAM;
variable ram_index :integer range 0 to 255; -- index into RAM array
BEGIN
if(ds'EVENT AND ds ='1') then
if(usb_rnw = '1') then -- read from RAM output to USB
ram_index := loc_addr;
usb_dout <= config(ram_index);
else -- in from USB write to RAM
config(ram_index) := usb_din;
end if;
end if; -- main ds event
end process usb_data;
I guess it is something to do with arrays. Has anyone any experience with this issue?
Nope
But I would recommend making the ram a signal rather than a variable to follow the altera coding guidlines properly.
Are you targeting the same device? E.g. if you used an ACEX device and now changed it for a Cyclone IV, Quartus may not be able to infer the RAM-block and thus generates the 4096 registers and the necessary multiplexers. EAB Ram in ACEX could be accessed without registering in- or outputs. In your code the address is unregistered which is not available in Cyclone (and Stratix) memory blocks.
Yes I'm targeting the same device.
I chaged from variable declaration to signal. Still the same problem.
I added the missing definitions for a full design, and it infers internal RAM with Cyclone III and default synthesis settings in Quartus V9.0.
library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity test1 is port ( ds : in std_logic; loc_addr : in integer range 0 to 255; usb_rnw : in std_logic; usb_din : in unsigned(15 downto 0); usb_dout : out unsigned(15 downto 0) ); end entity; architecture rtl of test1 is begin usb_data : PROCESS(ds) is TYPE RAM is array (0 to 255) of unsigned(15 downto 0); variable config :RAM; variable ram_index :integer range 0 to 255; -- index into RAM array BEGIN if(ds'EVENT AND ds ='1') then if(usb_rnw = '1') then -- read from RAM output to USB ram_index := loc_addr; usb_dout <= config(ram_index); else -- in from USB write to RAM ram_index := loc_addr; config(ram_index) := usb_din; end if; end if; -- main ds event end process usb_data; end;
