Hello I'm trying to migrate from quartus 5.1 to 9.0 sp2. The problem I have is that 9.0 generates much more elements (11,000 instead of 5,000) than 5.1. And it all happens because of this code.
usb_data : PROCESS(ds) is TYPE RAM is array (0 to 255) of unsigned(15 downto 0); variable config :RAM; variable ram_index :integer range 0 to 255; -- index into RAM array BEGIN if(ds'EVENT AND ds ='1') then if(usb_rnw = '1') then -- read from RAM output to USB ram_index := loc_addr; usb_dout <= config(ram_index); else -- in from USB write to RAM ram_index := loc_addr; config(ram_index) := usb_din; end if; end if; -- main ds event end process usb_data; I guess it is something to do with arrays. Has anyone any experience with this issue?Link Copied
Nope
But I would recommend making the ram a signal rather than a variable to follow the altera coding guidlines properly.- Mark as New
Are you targeting the same device? E.g. if you used an ACEX device and now changed it for a Cyclone IV, Quartus may not be able to infer the RAM-block and thus generates the 4096 registers and the necessary multiplexers. EAB Ram in ACEX could be accessed without registering in- or outputs. In your code the address is unregistered which is not available in Cyclone (and Stratix) memory blocks.
Yes I'm targeting the same device.
I chaged from variable declaration to signal. Still the same problem.
I added the missing definitions for a full design, and it infers internal RAM with Cyclone III and default synthesis settings in Quartus V9.0.
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity test1 is
port
ds : in std_logic;
loc_addr : in integer range 0 to 255;
usb_rnw : in std_logic;
usb_din : in unsigned(15 downto 0);
usb_dout : out unsigned(15 downto 0)
end entity;
architecture rtl of test1 is
begin
BEGIN
end if;
end;
