17261 Discussions
asynchronous bus implementation.
i am tring to implement an external bus interface which is connected to ARM chip.
oe, we, ce, addr, data signals were provided by MCU.
i have to drive my registers with 25Mhz internal clock.
so, there are two clock domains. metastable problems must be solved.
but i want to speed up the interface's r/w speed, which makes the external bus work about 50ns.
ce is active about 50ns.
we/oe remains 30ns active.
ce comes 20ns ahead of we/oe.
we/oe was selected as clock.
this design would need a two clock synchrounous mechenism for those signals.
it would be a long time for me, because some register have to be read immediately after write.
is there any one-clock synchronizer exist?
What's a "one-clock synchronizer"?
CE length of only 50 ns either requires oversampling the bus at a high rate, I guess at least 100 MHz, or operating the interface synchronous to the ARM clock. Some ARM variants are exposing a synchronous interface with a clock, otherwise the clock would need to be synthesized from the ARM input clock, and most likely phase synchronized to the bus signals.
Using OE and WE as clocks doesn't seem a straightforward solution to handle the bus.
We usually try to live with a slower bus, inserting some wait states.
one-clock synchronizer is a synchronizer need only one clock to synchronize clock domain.
it is compared to two filp flop synchronizer, which need two clock to synchronize.
If the clock is slow enough, you can utilize both edges for the synchronizer, instead of introducing a faster oversampling clock. It's against a clear, straightforward design, but may be useful anyway.
