avoir bounce with button
Hey,
how can i write my vhdl code to avoid bounce?
--- Quote Start ---
--- Quote End ---
Draw a flowchart of the basic functionality, and then write a behavioural implementation of that.
Use a counter to generate a suitable interval at which to test the button's input signal. Test it a number of times to see if it persists. Once the signal has passed that test you can declare the button pressed (or released).
I hope that's something you can attempt to code yourself...
Cheers,
Alex
