17268 Discussions
beginner's issue: register assignment never happens
Another beginners understanding problem..
In the following module I try to provide some input at "writedata", and "write" signal, and expect some incremented output on "readdata" and a "done" signal set. When I test the code with ModelSim, I see the assignment to readdata actually never happens. Actually the line of the assignment to readdata is not even breakpoint-able in ModelSim, it tells "no executible line". Why is that? How may I achieve an incremented assignment here, and what am I doing wrong?
... reg algo_out; initial algo_out = 8'b0; ...
EDIT: I posted the wrong code snippet, pls have a look into my other post, below! Sorry about all the mess!
algo_out is assigned zeros and nothing else. so read data follows
Oups! Sure, sry!!! I copy&paste'd the wrong version...
The version, now a bit more tested, but still with the same issue: readdata does not get assigned, is here:
module avalonmm_algo( input clk, input start, input reset, output reg leds, input write, input writedata, output reg readdata, output done ); parameter WAITING = 2'b00; parameter WORKING = 2'b01; parameter DONE = 2'b10; reg stage; // init? initial stage = WAITING; assign done = (stage == DONE); reg step; initial step = 2'b00; reg algo_in; initial algo_in = 8'b0; reg algo_out; initial algo_out = 8'b0; // STEP rules, DATA initialization and handling always @(*)begin if(stage == WAITING)begin leds <= 4'b0001; end if(stage == WORKING)begin leds <= 4'b0010; end if(stage == DONE)begin leds <= 4'b0100; // TODO: why is this always executed? end else begin leds <= 4'b1111; end end // procedural assignments for registers // clocked STAGE and STEP transition, here always @(posedge clk)begin if(reset)begin stage <= WAITING; step <= 2'b00; algo_in <= 8'b0; algo_out <= 8'b0; end else if(start)begin stage <= WORKING; step <= 2'b00; end else if(stage == WORKING)begin case(step) 2'b00: begin if(write)begin algo_in <= writedata; step <= 2'b01; end end 2'b01: begin algo_out <= algo_in + 1'b1; if(0 < algo_out)begin step <= 2'b10; end end 2'b10: begin readdata <= algo_out; // TODO why does this not assign? if(0 < readdata)begin step <= 2'b11; end end 2'b11: begin stage <= DONE; end endcase end end endmodule
Questions: as above and the comments I had, perhaps you still could have another look on it, and give me some hints?
I tried a quick check and I see read data acquiring values. It is likely your inputs or expectations are wrong
