공지
build issue with EDS
명예로운 기여자 II
3,352 조회수
hi all,
I built hello_world through make -f Makefile command, but it showed"arm-linux-gnueabinf-g++: error : /libpath:C:/altera/14.1/hld/host/windows64/lib/: Invalid argument", "arm-linux-gnueabinf-g++: error :alteracl.lib: no such file or directory" ......
It seems the path C:/altera/14.1/hld/host/windows64/lib/ is invalid on windows. this path seems to be modified to /cygdrive/c/altera/14.1/hld/host/windows64/lib/ ? and which file should I modify? or solve it in another way.
0 포인트
8 응답
명예로운 기여자 II
2,218 조회수
If I must build host application on linux ?
0 포인트
명예로운 기여자 II
2,218 조회수
I got this to compile on my windows 7 machine by making a small change to the makefile.
replace:
AOCL_LINK_CONFIG := $(shell aocl link-config)
with:
AOCL_LINK_CONFIG := $(shell aocl link-config --arm)
0 포인트
명예로운 기여자 II
2,218 조회수
Thanks to your answer, I will try.
0 포인트
명예로운 기여자 II
2,218 조회수
To let you know I had exactly the same issue, and the proposed workaround resolved the issue.
0 포인트
명예로운 기여자 II
2,218 조회수
I is beginner in this OpenCL theme and in yesterday has download the last version of HelloWorld, install last version of Quartus Std 17.1 & SDK for OpenCL with ARM DS-5, my board is c5soc, OS Win7 Prof.
And I see the same problem with "--arm" key in downloaded Makefile as is recommended from craueralt !
Where are trouble ? My output errors is:
/libpath:D:/intelFPGA/17.1/hld/host/windows64/lib: Invalid argument OpenCL.lib: No such file or directory
The command "aocl linkflags" says:
/libpath:D:/intelFPGA/17.1/hld/host/windows64/lib OpenCL.lib
In D:/intelFPGA/17.1/hld/host/windows64/lib I see the normal file OpenCL.lib.
How repair this bug ?
0 포인트
명예로운 기여자 II
2,218 조회수
A problem is in "invisible" key "--arm" for command in Makefile after "shell aocl link-config", which must return a list of ARM linker parameters instead x64.
If manually edit Makefile, clear AOCL_LINK_CONFIG, set to LIB_DIRS list of library directories and add to LIBS all need libs, then examples is compiled and runned after successful.
0 포인트
명예로운 기여자 II
2,218 조회수
--- Quote Start ---
--- Quote End ---
hi!
I have the same problem,have you solved it?
I want to change the output of "aocl link-config",how can I implement this?
By the way,do you know the output of "aocl link-config" depends on which variable's value ???
0 포인트
ygao15
초급자
2,218 조회수
I have the same problem as you,do you solved it? I am looking forward to your help.​
0 포인트
응답
