17253 Diskussionen
cant get one-hot with VHDL in quartus II 8.1
Geehrter Beitragender II
2.449Aufrufe
Can anyone help me with implementing a one-hot state machine in quartus II 8.1 with VHDL.
I created a simple test file and set the state machine processing to one-hot in 'More Analysis and Synthesis Settings'
When I go to simulate, the node finder gives me four registers for the four states, but one of the states remains undefined, and the encoding appears to be a combination type like grey or johnson.
Also tried an enumerated encoding which didnt work either.
I attached the code I was trying to use.
Thanks in advance for any help.
2 Antworten
1.685Aufrufe
In your example code, the FSM attributes must be deleted, to make Quartus recognize a state machine. But then it's synthesized in one-hot style, also in default auto mode.
I guess, you didn't consider, that the s1 state bit is always inverted, so that an all zero state vector corresponds to initial state s1.
1.685Aufrufe
Thanks FvM
The FSM deletion fixed it.
Antworten
