17255 Discussions
compilation issues (Quartus) Please Help
I am trying to implement a mean and max module.
It works on modulesim
If my parameter MxN= 262144;
--- Quote Start ---
Total combinational functions 127 / 21,280 ( 1 % )
Dedicated logic registers 98 / 21,280 ( < 1 % )
Revision Name max_mean
Top-level Entity Name max_mean
Family Cyclone IV GX
Total logic elements 143 / 21,280 ( 1 % )
Total registers 98
Total pins 99 / 167 ( 59 % )
Total virtual pins 0
Total memory bits 0 / 774,144 ( 0 % )
Embedded Multiplier 9-bit elements 0 / 80 ( 0 % )
Total GXB Receiver Channel PCS 0 / 4 ( 0 % )
Total GXB Receiver Channel PMA 0 / 4 ( 0 % )
Total GXB Transmitter Channel PCS 0 / 4 ( 0 % )
Total GXB Transmitter Channel PMA 0 / 4 ( 0 % )
Total PLLs 0 / 4 ( 0 % )
Device EP4CGX22CF19C6
Timing Models Final
--- Quote End ---
If my parameter MxN= 362144; OR parameter MxN= 162144;
--- Quote Start ---
Total combinational functions 1,655 / 21,280 ( 8 % ) Flow Status Successful - Mon Sep 26 14:12:28 2011
Dedicated logic registers 98 / 21,280 ( < 1 % ) Quartus II Version 11.0 Build 157 04/27/2011 SJ Web Edition
Total logic elements 1,655 / 21,280 ( 8 % )
Total registers 98
Timing Models Final
--- Quote End ---
I dont know what is going on?
Neither do we, without looking at your code, but that being said:
The most likely thing is your first constant is a nice power of 2 ie 262144 = 0x40000
where as the other two value you gave are not powers of 2, so my guess is that your logic allows the synthesis tool to optimize the design to just a few gates when you have a power of 2 in your constant.
Pete
That actually makes sense!!!
But will that optimize the WHOLE module. The module performs a mean and max.
here is a link to the code. I posted it in another website http://www.edaboard.com/thread225882.html#post963441
Also,
I have state machines in my project. Is it possible to see the hardware via netlist inside the state machine on Quartus? Every 'case' is suppose to implement something.
The answer about the different compilation results is in this code line
xin_mean<=xin_mean/MxN +Xin/MxN;
It's implementing two hardware dividers respectively a simple shift operation, if MxN is a power of two. The difference also catches your eye in the Quartus hierarchy browser.
