17254 Discussions
cyclonev_atom_ncrypt.v for synopsys VCS
STu1
I want to use synopsys VCS to run post-synthesis simulation.
In quartus_install_dir/eda/sim_lib/aldec & memtor can find cyclonev_atom_ncrypt.v, but VCS can't use it.
How can I get the cyclonev_atom_ncrypt.v for VCS?
KennyTan_Altera
You can just go to quartus -> tools -> launch simulation compiler to generate the library for your VCS.
Thanks​
STu1
Thanks for your response.
In quartus -> tools -> launch simulation compiler can't find VCS.
KennyTan_Altera
Are you using windows? Vcs only support in Linux. https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qpp-tp-simulation.pdf
Thanks​
STu1
So I need to install quartus linux version then launch simulation compiler to generate the library for your VCS,right?
KennyTan_Altera
If you were using windows, you will need to switch to Linux version and install the quartus Linux version. Quartus Linux version would not be supported in windows platform. Thanks​
