When i was simulating my VHDL coding in Quartus II web edition i am getting the following errors:
Error:Port "enable" does not exist in primitive "latch" of instance "u0" Error:can't elaborate user hierarchy "lut_0:06" But it's working well in the modelsim-altera software. I need the soln then only i can implement it in DE1 board. Thanks in advance.Link Copied
Show the code.
What do you mean with "simulating my VHDL coding in Quartus II web edition" different from using modelsim-altera?- Mark as New
this is just part the coding,
library ieee; use ieee.std_logic_1164.all; entity lut_0 is port( a,b,c,d : in std_logic; i0 : in std_logic:='0'; i1 : in std_logic:='1'; i2 : in std_logic:='0'; i3 : in std_logic:='1'; i4 : in std_logic:='1'; i5 : in std_logic:='0'; i6 : in std_logic:='0'; i7 : in std_logic:='1'; i8 : in std_logic:='1'; i9 : in std_logic:='0'; i10 : in std_logic:='0'; i11 : in std_logic:='1'; i12 : in std_logic:='1'; i13 : in std_logic:='0'; i14 : in std_logic:='1'; i15 : in std_logic:='0'; enable : in std_logic; FA : inout std_logic ); end lut_0; architecture ar of lut_0 is component latch port( d : in std_logic; enable : in std_logic; q : out std_logic ); end component; component sel_fa_0 port( a,b,c,d : in std_logic; l0,l1,l2 : in std_logic; l3,l4,l5 : in std_logic; l6,l7,l8 : in std_logic; l9,l10,l11 : in std_logic; l12,l13 : in std_logic; l14,l15 : in std_logic; Output : out std_logic ); end component; signal w0,w1,w2,w3,w4,w5,w6,w7,w8,w9,w10,w11,w12,w13,w14,w15 : std_logic; begin u0: latch port map(i0,enable,w0); u1: latch port map(i1,enable,w1); u2: latch port map(i2,enable,w2); u3: latch port map(i3,enable,w3); u4: latch port map(i4,enable,w4); u5: latch port map(i5,enable,w5); u6: latch port map(i6,enable,w6); u7: latch port map(i7,enable,w7); u8: latch port map(i8,enable,w8); u9: latch port map(i9,enable,w9); u10: latch port map(i10,enable,w10); u11: latch port map(i11,enable,w11); u12: latch port map(i12,enable,w12); u13: latch port map(i13,enable,w13); u14: latch port map(i14,enable,w14); u15: latch port map(i15,enable,w15);- Mark as New
Apparently a different entity with the name "latch" but other port names exists in your library.
There's e.g. a latch in altera_primitives_components.vhd. It's better to avoid ambiguous names like this.- Mark as New
Thanx...I changed the latch entity name..now that error is not coming...
But now i am getting the following Error: Can't place 1545 pins with 3.3-V LVTTL I/O standard because Fitter has only 311 such free pins available for general purpose I/O placement I am having Altera Cyclone II board..In my design i used 1545 I/O pins but Cyclone II only hav 311 pins.... any soln for this ...to check my design in the FPGA board... reply me ASAP..- Mark as New
what have you got at the top level?
Basically, the only solution is to use many many fewer pins (or get a buigger device, but I dont think there is one with 1545 IOs. Not even a Stratix 5)
Topic Options
