17255 Discussions
error:Port "enable" does not exist in primitive "latch" of instance "u0"
When i was simulating my VHDL coding in Quartus II web edition i am getting the following errors:
Error:Port "enable" does not exist in primitive "latch" of instance "u0"
Error:can't elaborate user hierarchy "lut_0:06"
But it's working well in the modelsim-altera software.
I need the soln then only i can implement it in DE1 board.
Thanks in advance.
Show the code.
What do you mean with "simulating my VHDL coding in Quartus II web edition" different from using modelsim-altera?
this is just part the coding,
library ieee;
use ieee.std_logic_1164.all;
entity lut_0 is
port( a,b,c,d : in std_logic;
i0 : in std_logic:='0';
i1 : in std_logic:='1';
i2 : in std_logic:='0';
i3 : in std_logic:='1';
i4 : in std_logic:='1';
i5 : in std_logic:='0';
i6 : in std_logic:='0';
i7 : in std_logic:='1';
i8 : in std_logic:='1';
i9 : in std_logic:='0';
i10 : in std_logic:='0';
i11 : in std_logic:='1';
i12 : in std_logic:='1';
i13 : in std_logic:='0';
i14 : in std_logic:='1';
i15 : in std_logic:='0';
enable : in std_logic;
FA : inout std_logic );
end lut_0;
architecture ar of lut_0 is
component latch
port( d : in std_logic;
q : out std_logic );
end component;
component sel_fa_0
l0,l1,l2 : in std_logic;
l3,l4,l5 : in std_logic;
l6,l7,l8 : in std_logic;
l9,l10,l11 : in std_logic;
l12,l13 : in std_logic;
l14,l15 : in std_logic;
Output : out std_logic );
end component;
signal w0,w1,w2,w3,w4,w5,w6,w7,w8,w9,w10,w11,w12,w13,w14,w15 : std_logic;
begin
u0: latch port map(i0,enable,w0);
u1: latch port map(i1,enable,w1);
u2: latch port map(i2,enable,w2);
u3: latch port map(i3,enable,w3);
u4: latch port map(i4,enable,w4);
u5: latch port map(i5,enable,w5);
u6: latch port map(i6,enable,w6);
u7: latch port map(i7,enable,w7);
u8: latch port map(i8,enable,w8);
u9: latch port map(i9,enable,w9);
u10: latch port map(i10,enable,w10);
u11: latch port map(i11,enable,w11);
u12: latch port map(i12,enable,w12);
u13: latch port map(i13,enable,w13);
u14: latch port map(i14,enable,w14);
u15: latch port map(i15,enable,w15);
Apparently a different entity with the name "latch" but other port names exists in your library.
There's e.g. a latch in altera_primitives_components.vhd. It's better to avoid ambiguous names like this.
Thanx...I changed the latch entity name..now that error is not coming...
But now i am getting the following
Error: Can't place 1545 pins with 3.3-V LVTTL I/O standard because Fitter has only 311 such free pins available for general purpose I/O placement
I am having Altera Cyclone II board..In my design i used 1545 I/O pins but Cyclone II only hav 311 pins....
any soln for this ...to check my design in the FPGA board...
reply me ASAP..
what have you got at the top level?
Basically, the only solution is to use many many fewer pins (or get a buigger device, but I dont think there is one with 1545 IOs. Not even a Stratix 5)
