I am trying to set up my ethernetblaster and having some problems.
When I tried the autodetect feature, it worked ok. However, I typed no password and the connection status was "authentication failure". This was expected. What was not expected is that I cannot change the password. I also cannot "remove server" because this button appears shaded! Next, I set up the ethernetblaster server on another IP address, and tried to connect providing the correct password. In the "currently selected hardware", and indication of the server appears but when I close the "Hardware setup" window, the programmer still keeps saying "No hardware" in the top line. I suspect that if I could remove the "bad" server (actually, now I have even 2 of them, with a fake one showing "connecting..." all the time) I could try again but this seems impossible. Any hints? PereLink Copied
go to the command line
type jtagconfig it will list all available config hardware to delete a config hw setup, type jtagconfig --delete 1 where 1 is the number from the list provided in the initial jtagconfig command --dalon- Mark as New
Thanks. It worked!
Btw, the correct command is jtagconfig --remove (at least for my version of jtagconfig) Pere- Mark as New
i always have to check the help....
on a side note, i never add the ethernetblaster using quartus.
do jtagconfig --addserver my_ethernet_blaster_ip_or_hostname password --dalon- Mark as New
Ok. I'll look at that!
Thanks. Pere
Topic Options
