ethernetblaster problem
I am trying to set up my ethernetblaster and having some problems.
When I tried the autodetect feature, it worked ok. However, I typed no
password and the connection status was "authentication failure". This
was expected.
What was not expected is that I cannot change the password. I also
cannot "remove server" because this button appears shaded!
Next, I set up the ethernetblaster server on another IP address, and
tried to connect providing the correct password. In the "currently
selected hardware", and indication of the server appears but when I
close the "Hardware setup" window, the programmer still keeps saying "No
hardware" in the top line.
I suspect that if I could remove the "bad" server (actually, now I have
even 2 of them, with a fake one showing "connecting..." all the time) I
could try again but this seems impossible.
Any hints?
Pere
go to the command line
type jtagconfig
it will list all available config hardware
to delete a config hw setup, type
jtagconfig --delete 1
where 1 is the number from the list provided in the initial jtagconfig command
--dalon
Thanks. It worked!
Btw, the correct command is
jtagconfig --remove
(at least for my version of jtagconfig)
Pere
i always have to check the help....
--dalon
on a side note, i never add the ethernetblaster using quartus.
do
jtagconfig --addserver my_ethernet_blaster_ip_or_hostname password
--dalon
Ok. I'll look at that!
Pere
