17261 Discussions
expecting a description
what is the meaning (and reason) of syntax error:
10170 Verilog HDL syntax error at lights.v(6) near text ";"; expecting a description
(line 6 is the "endmodule"; using 13.01 Quartus; I am using a sample code from a book;
as far as I could check, the syntax is correct)
Thanks in advance
module clk_gen; reg clk; initial clk = 1'b0; always# 10 clk = ~clk; initial# 60 $finish; endmodule;
endmodule should not have a semicolon (;) at the end
--- Quote Start ---
--- Quote End ---
Thank you, really. (BTW: I think an empty instruction should be tolerated, and the error message could be more informative).
I have, however, more problems.
About line, containing '$finish', the compiler gives the warning "ignoring unsupported system task".
(As far as I know, $finish should be supported)
The bigger problem is the error the compiler reports:
"Can't synthetise current design -- Top partition does not contain any logic"
Which is absolutlely true. But, I did not want to synthetise, just to simulate and show the waveform.
Is there any setting that allows to to that?
And in general, shall I change some setting to compile ONLY for simulation?
--- Quote Start ---
--- Quote End ---
FYI, moving to SystemVerilog will allow the null statement.
