17256 Discussions
fatal error with quartus 10.1
hello,
after installing quartus 10.1 with permanent license and support evice and niosII.
on the pin planner, after define all pins group and begin to define pin location for IO
the followed message appear
*** Fatal Error: Access Violation at 00000000
Module: quartus.exeCould not obtain stack trace
Quartus II Version 10.1 Build 153 11/29/2010 SJ Full Version
thanks.
n.b : uninstall and re-install quartus 10.1 not solve the problem
you will need to file a service request with step by step instructions to reproduce the error. if you can't file service requests posting here might help
*** Fatal Error: Breakpoint
Module: quartus.exe
Stack Trace:
0xfc0eb: ADB_CDB_INTERFACE_BODY_IMPL::get_adb_node_by_name + 0xb (ace_adb)
0x4b332: GEDQ_FRAME_WND::update_copy_paste + 0x162 (sys_mdb)
0x55968: GEDQ_FRAME_WND::update_actions + 0x8 (sys_mdb)
0x6322: QGQ_MAIN_WINDOW::about_to_show_edit_menu + 0x72 (SYS_QGQ)
0x6cc8: QGQ_MAIN_WINDOW::on_sub_wnd_activated + 0xb8 (SYS_QGQ)
0x7601: QGQ_MAIN_WINDOW::qt_metacall + 0x391 (SYS_QGQ)
0xdb39e: QMetaObject::metacall + 0x3e (QtCore4)
0x31fbcb: QMdiArea::paintEvent + 0x12bb (QtGui4)
0x322c09: QMdiArea::event + 0x3f9 (QtGui4)
0x323a6a: QMdiArea::qt_metacall + 0x12a (QtGui4)
0x4421a: AFCQ_MDI_AREA::qt_metacall + 0x1a (GCL_AFCQ)
0x3240dc: QMdiSubWindow::windowStateChanged + 0x2c (QtGui4)
0x724a4: QApplication::winFocus + 0x24 (QtGui4)
0x75aa2: QApplicationPrivate::translateTouchEvent + 0x1012 (QtGui4)
End-trace
the error occur when i swift from pin placement management page to design page....
