17267 Discussions
foreach in systemverilog
What is wrong with this piece of code? Questa has no problem with it but Quartus does. Quartus has no issues with it if I remove the foreach and replace it with generate statement.
always_ff@(posedge register_if.clk or negedge register_if.rstn)
if(!register_if.rstn)
begin
foreach (int_stat_update_cnt_reg[intStatIter]) begin
int_stat_update_cnt_reg[intStatIter] <= 'd0;
end
foreach (int_stat_cnt_reg[intStatIter]) begin
int_stat_cnt_reg[intStatIter] <= 'd0;
end
end
<... snip ...>
Generate statement as below works -
genvar intStatIter;
generate for (intStatIter=0;intStatIter<NUM_OF_INT_STAT_REG; intStatIter+=1)
begin : intStat_gen
begin
//foreach (int_stat_update_cnt_reg[intStatIter]) begin
//end
//foreach (int_stat_cnt_reg[intStatIter]) begin
//end
end
Might help if you told us what problem Quartus has with it.
Yes! Of course... Quartus does not compile with foreach statement... I just assumed that it was obvious because all I use Quartus is to compile the code i.e. synthesize and p&r.
Quartus thinks it's a syntax error atleast the error seems to suggest that. Don't remember or have the exact error in front of me. But it doesn't matter any more since Altera's support indicated that "foreach" statement is not supported Quartus 12.0. Quartus 12.0 help seems to indicate all loop constructs are supported.
