17267 Discussions
how to creat noise signal in vhl
i have problems: How to creat noise gaussian or normal noise in vhdl ??? and how to simulate sine wave and sin wave+ noise in modelsim altera
--- Quote Start ---
--- Quote End ---
shift register based prbs can generate pseudo random noise.
LUTs also can be used to store whatever type of noise you get from tools like matlab e.g. gaussian.
You add noise signal to your signal sample by sample.
sine wave can be generated from luts by hand or nco compiler.
--- Quote Start ---
--- Quote End ---
how LUTs can store signal ,and how to convert gaussan from matlab to vhdl,i đon't understand ???
how can generate sine wave by LUTs( i know nco blocks)
--- Quote Start ---
--- Quote End ---
insert your data in mif files for ram to play
--- Quote Start ---
--- Quote End ---
I didn't say that. you create mif file from data
--- Quote Start ---
--- Quote End ---
use nco compiler, that does it all for you
You will need to make some research for all that before diving as it seems you are a beginner
Are you talking about creating noise only for simulation, or from an FPGA?
--- Quote Start ---
--- Quote End ---
yeah,i'm a beginner,need to learn more
--- Quote Start ---
--- Quote End ---
just for simulation,thanks
VHDL does have a "uniform" function in the math_real package than can generate random numbers between 0.0 and 1.0, that you can use to inject randomness into your design.
Also, have a look at this http://osvvm.org/
It is a package of functions for constrained random generation with various distrubutions (including gaussian)
PS. It is not for VHDL beginners though. Would make a good project (and you would learn a lot of the features of VHDL)
I'm surprised Dave hasn't weighed in on this, he has written an excellent tutorial on the subject along with sample code;
http://www.ovro.caltech.edu/~dwh/cor...r_tutorial.pdf
http://www.ovro.caltech.edu/~dwh/cor...torial_src.zip
Ha! You beat me to it :)
thanks,maybe i just simulate in matlab before
--- Quote Start ---
--- Quote End ---
The tutorial has MATLAB code as well as VHDL code.
Cheers,
Dave
