17237 Discusiones
how to determine the parameter of set_max_fanout?
Colaborador Distinguido II
2.471 Vistas
Hi:
I have known the function of set_max_fanout,but I don't understand how to confirm the parameter which following set_max_fanout.please help me!
thank you!
0 kudos
4 Respuestas
1.496 Vistas
That's the max fanout value. So if a register has a fanout of 35, and you do that assignment, you'll end up with 5 copies, 4 that have a fanout of 8 and 1 that has a fanout of 3. The following might help:
http://www.alterawiki.com/wiki/register_duplication_for_timing_closure
1.496 Vistas
is the parameter confirmed acconding to the target library?
1.496 Vistas
Are you talking about an ASIC?
Max fanout is your constraint that you would manually enter to help timing. You can enter whatever value you want. The main purpose is to help the fitter place logic closer together, and hence achieve better timing.
1.496 Vistas
ok,I will look up some data.thanks for your response!
Responder
