how to estimate power
hi!
I use the Quartus II 6.1 in my work
Ineed to estimate the power of a program implanting on the FPGA (Altera Startix)
my projet was composed on two parts (software and hardward) so I need the power of tow parts of projet
when using "powerplayer poweranalyser tool"in the quartus II I estimate only hardware part
what can I do?
thank you
does the "software part " means NIOSII C code?
if yes, it only influent the hardware logic toglling rate.
so you can just set proper toggle rate in Powerplayer, so you can get the whole power.
thanks
