17255 Discussions
how to implement two megafunctions by serial?
hi,
im trying to implement altfp_add_sub megafunction and altfp_mult megafuntion in a block design file. In the begining they look fine but when i finished the compilation part,i found only the adder inputs and outputs in the node finder tool. i couldnt found the mult I/O parts in the node finder.
And also when i finished the functional simulation netlist generation,i found this Warning: Using design file controller.v, which is not specified as a design file for the current project, but contains definitions for 15 design units and 15 entities in project.
https://www.alteraforum.com/forum/attachment.php?attachmentid=414 (the block design file)
is there any possibility to implement two megafunctions by serial?
thank you
It's surely possible to use two series connected Megafunctions in a bdf design. But I wonder, how you can use single bit input ports adda and addb for the input busses and a non-bus connector line for a bus signal?
i dont know how to promote the input and the outpus pins on the megafunction. i think i just compile only the megafunction of add_sub.:confused: how i will do it? i want to promote these two megafunctions in one block design file. or any? thank you for your interest
Just connect the in- and outputs. But you need bit vector ports with busses (e. g. adda[63..0]) and thick line bus connectors.
i found another solution;
module ust_module(clock,a,b,result,overflow,underflow); input clock; input a,b; output result; output overflow,underflow; wire c; wire d; mult2 carpici2( .aclr(), .clk_en(1'b1), .clock(clock), .dataa(d), .datab(64'h4000000000000000), .denormal(), .indefinite(), .nan(), .overflow(overflow), .result(result), .underflow(underflow), .zero()); mult carpici( .aclr(), .clk_en(1'b1), .clock(clock), .dataa(c), .datab(64'h4000000000000000), .denormal(), .indefinite(), .nan(), .overflow(), .result(d), .underflow(), .zero()); adder toplayici( .aclr(), .clk_en(1'b1), .clock(clock), .dataa(a), .datab(b), .denormal(), .indefinite(), .nan(), .overflow(), .result(c), .underflow(), .zero()) ; endmodule it works also
but there is another problem happens, i want to connect the result to input b but i want to add a d-flipflop on the line. or an shiftreg but these ffs are using 8 bits but my output bus is 64 bits. i want to use a mux-demux but i couldnt find any demux megafunction in quartus. Are there any option to change the bit selection in dff or shiftreg, or any demux example that i can use?
I don't understand the problem. Megawizard created FF can have any width, also FF inferred from HDL code.
