17265 Discussions
implicit declaration of function ‘send_sig_info’ error
I am a student. I want to use OPenCL to write code for my FPGA. I installed FPGA SDK standard edition 17.1 in Ubuntu 16.04. After that I installed intel fpga runtime environment for opencl linux x86-64. After sourcing the script init_opencl.s, I was able to verify my installation using 'aocl version' command. After that I tried to install an FPGA board. So I tried the command 'aocl install' command.
It stopped with an error saying/tmp/opencl_driver_tf7ebm/aclpci.c:343:17: error: implicit declaration of function ‘send_sig_info’ [-werror=implicit-function-declaration] int ret = send_sig_info(aclpci->signal_number, &aclpci->signal_info, aclpci-
Complete output of the command:
/media/deepak/82d940f9-6526-47c8-8053-79204d78529f/deepak/intelFPGA/17.1/aclrte-linux64/board/a10_ref? y aocl install: Running install from /media/deepak/82d940f9-6526-47c8-8053-79204d78529f/deepak/intelFPGA/17.1/aclrte-linux64/board/a10_ref/linux64/libexec /media/deepak/82d940f9-6526-47c8-8053-79204d78529f/deepak/intelFPGA/17.1/aclrte-linux64/board/a10_ref/linux64/libexec/install: 9: /tmp/opencl_driver_tF7ebM/aclpci_queue.o CC /tmp/opencl_driver_tF7ebM/aclpci.o /tmp/opencl_driver_tF7ebM/aclpci.c: In function ‘aclpci_irq’: /tmp/opencl_driver_tF7ebM/aclpci.c:343:17: error: implicit declaration of function ‘send_sig_info’ int ret = send_sig_info(aclpci->signal_number, &aclpci->signal_info, aclpci- ^ cc1: some warnings being treated as errors scripts/Makefile.build:308: recipe for target '/tmp/opencl_driver_tF7ebM/aclpci.o' failed make: *** Error 1 Makefile:1550: recipe for target '_module_/tmp/opencl_driver_tF7ebM' failed make: *** Error 2 make: Leaving directory '/usr/src/linux-headers-4.13.0-36-generic' aocl install: failed. deepak@deepak:deepak$ aocl install
Help me out.
Deepak
Ubuntu is not officially supported by the Intel FPGA SDK for OpenCL, and even though kernel compilation might work correct, the PCI-E driver likely won't (as is your case):
http://dl.altera.com/requirements/17.1/
I recommend using a supported operating system.
If you insist on using Ubuntu, you can take a look at this thread and see if the provided solution works for you:
http://www.alteraforum.com/forum/showthread.php?t=56568
Thanks. I have now installed it in Windows 10. But the problem now is that aoc command is compiling a hello world program for DE2 board for 2.5 hours.
The command I used:
aoc device\hello_world.cl -o bin\hello_world.aocx --board de5net_a7
hello_world.aocx content:
// AOC kernel demonstrating device-side printf call
__kernel void hello_world(int thread_id_from_which_to_print_message) {
// Get index of the work item
unsigned thread_id = get_global_id(0);
if(thread_id == thread_id_from_which_to_print_message) {
printf("Thread# %u: Hello from Altera's OpenCL Compiler!\n", thread_id);
The following is message after executing the above command:
Warning: Please use -board=<value> instead of --board <value>
aoc: Running OpenCL parser....
aoc: Optimizing and doing static analysis of code...
Compiling for FPGA. This process may take a long time, please be patient.
Still the compilation has not stopped.
Depending on the characteristics of your machine (CPU speed, memory size, etc.) the compilation could take multiple hours.
Okay I understand. The reason why asked is that the kernel code looks simple and yet it took lot of time. That is why I asked. Thanks anyway
EBozo
This happened to me and my solution is
Add #include <linux/sched/signal.h> to the aclpci.h file.
The location of the prototype, send_sig_info, changed, which is not in linux/sched.hanymore for the newer kernel, so that it failed to compile.
https://forums.intel.com/s/question/0D50P00003yyTBTSA2/de5net-opencl-support-on-ubuntu-1610?t=1541575434952
JMilt1
EBozo's fix also worked for me - thanks! Much better than Altera's response of 'Ubuntu not supported' 🙂
