initializing M-RAM
Q's MegaWiz does not let me setup a MIF or a HEX for a M-RAM.
I would like to let this device come up with a predifined pattern in the RAMs. (never changes).
Ist there a way to do this though? - over the way of the system content editor ?
... via JTAG ?
I need a way for operational mode not only during development process ...
The only idea I currently have, is to use aother small RAM, load it with a ZIP file and unpack the data while setup phase. (a strange idea, of course :D )
--- Quote Start ---
--- Quote End ---
The M-RAM itself does not support memory initialization during configuration. This is documented in the device handbook.
I get the same problem. Can you try this way:
use an extern eeprom, say 24c32, depending on your size. store your data in the eeprom.
implemente a I2C interface and related read logic in your fpga.
whenever your fpga reset, it can read data from eeprom and init your ram.
You may need a init_done signal to let other logic know when to start their operation.
This would require a new (modified) hardware which I cannot create. Anyway there is the opportunity to do this configuration from an external PC over PCI. :cool:
It would have been just fine to have it ready configured in the data stream.:rolleyes:
Use M4K blocks to initialize data. You can go up to 256 KB in a stratix 2 (180) fpga.
I cannot, since the Fitter ran out of M4Ks.
--- Quote Start ---
This would require a new (modified) hardware which I cannot create. Anyway, there is the opportunity to do this configuration from an external PC over PCI. :cool:
It would have been just fine to have it already configured in the data stream.:rolleyes:
--- Quote End ---
Yes, this will be your best approach.
It's all in the details.
Good luck,
Avatar
