17252 Discussions
logic simulation error of Quartus (Quartus Prime 21.1) Lite Edition
jj16
I wanted to do logic simulation with Quartus (Quartus Prime 21.1) Lite Edition, but I got the following error.
Error: Can't launch Questa Intel FPGA Simulation software -- make sure the software is properly installed and the environment variable LM_LICENSE_FILE or MGLS_LICENSE_FILE points to the correct license file.
Error: NativeLink simulation flow was NOT successful
Any ideas what could be causing the error?
SyafieqS
Did you properly setup the license? Lite is free but still need license, You need to generate in SSLC and specify the location or using env variable. Also please make sure the path in quartus calling Questa in correct
SyafieqS
May I know if there is any update from my previous reply?
Did you able to solve it. Let me know
SyafieqS
 As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 10/10 survey
jj16
Sorry for the late reply.
I understand the above matter.
Thank you for your response.
